wiring and such.
Old Nov 23, 2003 | 11:00 PM
Matts72's Avatar
Matts72
wiring and such.
Well I don't really expect to get an answer in here, but I figured Eric would move my thread.
What wires do I need to splice to get a four pin trailer harness setup on my 79 F150. It never had any kind of trailer wiring from the factory, and the only wiring kits I can find are the plug in types.
I am planning on towing an 83 Ranger from Minnesota to Montana this summer, and I thought I should put some wiring in for the trip .
Thanks in advance, Matt
Old Nov 24, 2003 | 12:00 AM
acerockola77's Avatar
acerockola77
You could go test each one by one and see which is which. That's what I did, works well until you wire your right and left turn sigals wrong on your trailer
Old Nov 24, 2003 | 12:04 AM
Matts72's Avatar
Matts72
Yeah I figured it would be guess and check with the wiring. Thanks
Old Nov 24, 2003 | 11:33 PM
dtpatt2's Avatar
dtpatt2
You want a 4-flat? You're going to have brakes, correct? You have a controller? Sounds like you need at least a 6 round.
