tires
Old Nov 23, 2003 | 10:15 PM
tfdcapt's Avatar
tfdcapt
tires
I have a 2000 psd 250. need information on tires. wanting to put taller tires on the truck to fill in the fender wells a bit.
I have been told that i will need to take it in and have the computer reprogrammed to make the tranny shift properly. Is this true and if I dont what could happen
Old Nov 23, 2003 | 11:25 PM
theologian's Avatar
theologian
You can program the tire size in yourself. I am uncertain of the procedure to do this, but it is a thing someone here will have done, and will be able to walk you through.
Theo
Old Nov 24, 2003 | 06:23 AM
Skeetshooter's Avatar
Skeetshooter
The dealer will charge you around $80.00 to install the adjusted program for taller tires (It takes about 3 min to install). This will correct the speed-o, however I'm not sure the tranny shift points are adjusted.
