Exhaust Leak?????
Old Jan 17, 2024 | 07:22 PM
Larry115's Avatar
Larry115
Exhaust Leak?????
Hey I didn’t create this just because missed you guys, lol. I hooked up my trailer to my 85 Ford F350 and went and picked up 2 tons of hay. I was almost home and out of know where it sounds like an exhaust leak…I’ve heard one before. It gets louder as I accelerate. What is the first thing I should do to diagnose? Also, is this something I can tackle myself? Can I occasionally drive the truck in this condition until the weather warms up? It’s great to be back 😵‍💫😵‍💫
Thank You
Larry
Old Jan 17, 2024 | 08:29 PM
DirtyFerd's Avatar
DirtyFerd
Locate the leak. Have somebody sit in the truck and power brake it and listen for the source. Check your manifolds to see if they're cracked or whether it's just the gasket at the head or where the exhaust pipe connects. It could also be the pipe that goes from the back of one head to the other for your EGR. Or maybe the exhaust pipe itself is cracked and needs welding or replaced. If it's the manifold gasket, you can ride with that for awhile, although it's giving your O2 sensor a lean reading. The pipe on the back of the head should be replaced or plugged if it's faulty
Old Jan 17, 2024 | 08:32 PM
DirtyFerd's Avatar
DirtyFerd
I don't know for certain that you have the pipe across the back of the heads, in just trying to cover all the scenarios here
Old Jan 17, 2024 | 08:40 PM
Larry115's Avatar
Larry115
Thank you I’ll get my wife out there with me tomorrow…
Old Jan 17, 2024 | 09:05 PM
FuzzFace2's Avatar
FuzzFace2
Its not really good to drive with an exh leak and even more so in winter with the windows rolled up as CO2 in the cab has no way to get out.
You can take a shop vacuum and switch it so it blows out and hook it to the tail pipe and turn it on high and check the system to see where it is blowing out of.
Dave ----
Old Jan 17, 2024 | 10:36 PM
Franklin2's Avatar
Franklin2
460's are famous for the exhaust manifolds leaking at the cylinder and head and developing cracks also.
Old Jan 21, 2024 | 11:57 AM
Larry115's Avatar
Larry115
Evidence presentation 😵‍💫
Okay I haven’t tackled this job yet because I’ve been out hunting. This morning I started my truck so I could narrow down where the ticking noise is coming from. Man it just seems to come from no specific spot. I’ll take my wife out there in a few to see if she can help narrow it down. Although, as I revved the engine the ticking would speed up. If I pushed harder on the gas causing the engine to run higher at a certain point the ticking would go away…I’m confused. Is there an explanation for this? Also, any suggestions?
Larry
Old Jan 21, 2024 | 12:05 PM
BigBlue2's Avatar
BigBlue2
Sounds more like lifter noise than exhaust leak which gets louder with rpms
Old Jan 21, 2024 | 01:11 PM
Larry115's Avatar
Larry115
Is there a way I can isolate the lifters as the problem from the exhaust? What is the fix if lifters?
Larry
Old Jan 21, 2024 | 01:40 PM
Franklin2's Avatar
Franklin2
When the engine is dead cold, start it up and then quickly run your hand around the exhaust manifolds feeling for air puffing out. You can do this for a few seconds till the engine gets hot. If you can't find it, stop it and let it cool off again and then do it again where you didn't get to the first time.
You can also take a very good flashlight and carefully inspect around the exhaust manifolds, and where they connect to the y-pipe. If you see any black, that is where it's leaking. You can then verify this with the hand trick on a cold start-up.
Old Jan 21, 2024 | 06:36 PM
Larry115's Avatar
Larry115
Okay here’s an update. My neighbor, Harry, did exactly what Dave (Franklin) recommended and we couldn’t find an obvious leak…darn it! With the engine running I put a piece of cardboard over the end of the exhaust and the ticking changed pitch dramatically and sorta sounded to speed up…hard to be sure about that part. But, plugging the exhaust changed things for sure. We both believe the ticking is definately an exhaust leak. On the drivers side manifold there is a missing bolt, but I noticed that long before the leak. I’m wondering if there a broke off bolt and it’s simply held tight…who knows. Here’s another question. Should I just pull the exhaust pipes from the manifold and then pull both manifolds, clean them up, install new gaskets and put it all back together? I don’t mind buying new exhaust manifolds if you guys think it’s best…just let me know. Let me know what step I should take next…
ps: my rear brakes work incredible…again thank you.
Larry
Old Jan 21, 2024 | 07:19 PM
BigBlue2's Avatar
BigBlue2
Probably the first thing is to find your leak. A missing manifold bolt is a good place to look closer at. Feeling around cold and you can't find it? Maybe try a short piece of hose as a stethoscope to your ear to help zero in?
Old Jan 21, 2024 | 07:30 PM
BigBlue2's Avatar
BigBlue2
There is a smoke test. Using a smoke machine to force smoke into the exhaust. Google it.
Old Jan 21, 2024 | 07:48 PM
Larry115's Avatar
Larry115
I’ll google it right now. I was reading about blowing air from the tail pipe and a bottle of soapy water and start spraying…what do u think?
Old Jan 21, 2024 | 08:32 PM
BigBlue2's Avatar
BigBlue2
Soapy water might help right at first before it's hot. And air or smoke through the tail pipe can help.
