Sponsored by: Auxito
Loud Squealing when giving gas
Old Jan 13, 2024 | 01:05 PM
silverchariot's Avatar
silverchariot
1st Gear
I have a 2002 ford f150 lariat edition, it has been making this high pitched chirping/squeaking this past month; it only ever starts up when I give the truck gas, it’ll make a loud repetitive chirp/squeal when I give gas but if I let off and let it slowly idle the noise will die down back to silence. I’d appreciate it to hear any feedback or guesses y’all could muster up
Old Jan 13, 2024 | 01:27 PM
RLXXI's Avatar
RLXXI
Vacuum leak or worn belt/tensioner. Accessory pulley bearing, idler pulley bearing. Hard to say. Need to look at it to be sure.
Old Jan 13, 2024 | 01:28 PM
charlie g's Avatar
charlie g
FTE Community Team
chirp/squeal start by check all of the drive belts, my bet is since it's a 2002 your going to be changing them, the tensioners and guide bearing
Old Jan 13, 2024 | 03:38 PM
BareBonesXL's Avatar
BareBonesXL
Remove the belt and start the engine. It will be fine for a minute or two. If the noise goes away, it's belt-related. If it doesn't it's something else. Spin the various pulleys by hand, you might find the bad one. You can feel it.
96f150
1997 - 2003 F150
Mar 14, 2017 09:02 AM
Oslo
13
Mar 21, 2011 09:02 PM
Fordenthusiasts
15
Apr 26, 2008 09:27 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
13
Sep 17, 2004 12:42 PM
Russell Avery
Jul 24, 2002 07:14 AM
