Sponsored by: Kumho
3/4 wheel bolt pat.
Old Nov 23, 2003 | 08:22 PM
Cliford's Avatar
Cliford
3/4 wheel bolt pat.
I can buy a set of wheels and tires from 2000 3/4 ton 8 hole.
I tryed to put them on my old 1976 3/4 and would not fit.
What years will they fit?
Thanks Clifford
Old Nov 23, 2003 | 10:37 PM
85351ho's Avatar
85351ho
those wheels have the 8x 170mm hubcentric bolt pattern, they will only work on 99 and up superdutys, you need the regular old 8x6.5 bolt pattern
Old Nov 24, 2003 | 06:04 PM
mx495's Avatar
mx495
85351 is right. Basically you can use any 8 lug wheel off of any brand truck, except 99 and up Ford Superduties, there metric. Just make sure if you have a 16 or 16.5 inch wheel that the wheel yiour using is big enough. Sometimes 15 wheels wont clear a drum oor rotor.
Old Nov 25, 2003 | 10:09 PM
lrd56's Avatar
lrd56
8 hole wheels
i have a 71 f250 i tried using chevy 8 hole wheels they work on the front not the back chevys use a 4 and 3/4 inch center. dodge and ford use 5 inch centers . if your careful you can either grind out or cut the chevy wheels to fit but if you do that the wheels can be a drag to balance my truck had stupid 16.5s on it i modiefied chevy 16s till i found some stupid white spoke 16 inch ford wheels the wheel i like are the old 16 inch steel wheels if i can find some im going to have them chromed
