5.0 swap help
Old Jan 9, 2024 | 03:00 AM
Mexicanshark88's Avatar
Mexicanshark88
4wd High
5.0 swap help
So i have a 93 f150 that im swapping a 5.0 into after my 4.9 blew. I have the wiring harness and the flywheel from a 93 5.0, and the engine is from an 88 f150 5.0 that i have as a donor truck. Some other parts ive obtained are: HO cam out of a 99 explorer, along with the matching lifters and pushrods, and some crane cams 1.7 roller rockers. Im gonna run the stock speed density setup from the 93, so will this work, and if so, what else do i need for this to work?
Old Jan 9, 2024 | 03:48 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m not sure. Have you confirmed that the ‘88 block is already drilled and tapped for the spider bolts?
Old Jan 9, 2024 | 06:27 AM
Mudsport96's Avatar
Mudsport96
What transmission is in BOTH trucks? The AOD uses a different flexplate than the E4OD I believe.
Old Jan 9, 2024 | 09:21 AM
Conanski's Avatar
Conanski
That is an F4TE roller cam not a HO cam.. but it's better than what's in an early truck motor.
What about the spider retainer and dogbones for the roller lifters?
You will need a PCM for a 5.0 and whatever trans the '93 has.
Old Jan 9, 2024 | 09:59 AM
Mexicanshark88
4wd High
yes ive confirmed that
Old Jan 9, 2024 | 10:02 AM
Mexicanshark88
4wd High
The 93 is a manual, so the m5odr2.
I have those aswell, got the entire setup from the same vehicle
Trans is a manual trans, so theres no worries there. The donor truck has the pcm.
Fungus232
13
May 12, 2015 10:55 PM
TheGageinator
Jul 20, 2013 12:06 AM
Jesus parra
Feb 5, 2010 11:02 PM
bamajim1960
Aug 5, 2009 02:58 PM
V8muscle
Mar 24, 2008 11:46 AM
