Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford P500 looking for help
Old Jan 4, 2024 | 11:48 PM
Ryanb1979's Avatar
Ryanb1979
Trailering
Hello, I am a new member here. I just picked up the 1965 Ford P-500.
It was hauled on a flatbed to my house because the brakes and clutch are bad. When driving it into the driveway I tried to get into reverse... Well it didn't catch, the clutch let out while in a forward gear and it pitched forward, and the Ford 300 died. The shifter now is completely loose and the transmission is stuck in a forward gear.
I think it is the np435 transmission.
So does anyone have suggestions?
At this point, if the transmission is toast I am considering an automatic. Is there anything worth considering? I want good fuel economy and the ability to haul and tow.
1956 Ford P-500
Vin tag
Thanks in advance!!
Old Jan 5, 2024 | 12:38 AM
85e150's Avatar
85e150
I'll get back to you tomorrow.
The shifter and top cover can be removed from your transmission. You will be able to get the transmission in neutral and get the shifter working again. Repair parts might be required but they are available. Your transmission code A indicates the NP435.
More later.
Old Jan 5, 2024 | 04:29 PM
85e150's Avatar
85e150
P500 = P500 gas
B = 300 1V six cylinder gas
L = Michigan Truck Plant
793347 = 1966 numerical series, December 1965 production
154 = 154 inch wheelbase
9 = Color code not found in MPC or '65 or '66 shop manual.
P500 = P500 gas, 15,000 lbs GVWR
88 = Not shown, but it's the walk in van body.
A = New Process model 435 transmission
42 = Rockwell D-100NXT single speed rear axle, 13,000 lbs capacity, 6.20 ratio
No front axle code, indicating standard Ford front axle.
71 = Los Angeles District Sales Office
Is that all there is--just the "71"?
As to usage, you will need to get it weighed empty to see what your tare weight is, then subtract that from 15,000 for payload. Be sure to allow for driver weight and all the other stuff besides cargo.
Towing? You can probably tow 1000 to 3500 lbs without too much trouble, but I'd be looking for trailer brakes over 1000 lbs, required or not. Hills will be miserable.
Fuel economy? 8 to 15, depending on tailwind.
What wheels does that have? Tubeless tires? I don't see a locking ring, so either tubeless or widowmakers.....
Old Jan 5, 2024 | 07:34 PM
Ryanb1979's Avatar
Ryanb1979
Trailering
Originally Posted by 85e150
P500 = P500 gas
Wow thank you for all the details.. it all makes sense for what I am seeing.
The radiator leaks, anyone have a part number or know what I can use that fits? I removed it and can't find a part number.
Thank you all!!
Old Jan 5, 2024 | 08:05 PM
85e150's Avatar
85e150
Best bet is to try and have it fixed.
Old Jan 5, 2024 | 11:51 PM
Ryanb1979's Avatar
Ryanb1979
Trailering
I will see what I can do with flushing and cleaning the radiator and engine.
The exhaust is cracked so I need to replace it. I am leaning towards something like the headman headers.
Anyone have a good used exhaust and something like the offenhauser intake?
I can't wait to get this beast rolling well again.
Old Jan 6, 2024 | 11:38 PM
Ryanb1979's Avatar
Ryanb1979
Trailering
Well, it is actually a brass tank so I soldered it up and it holds water.
Old Jan 7, 2024 | 04:15 PM
FuzzFace2's Avatar
FuzzFace2
If you can find a Offy intake good and header should help for power.
But if you want to keep the V1 carb look for EFI exh manifolds and factory Y pipe as that will help flow.
Dave ----
Old Jan 7, 2024 | 06:10 PM
Ryanb1979's Avatar
Ryanb1979
Trailering
As much as I want to be a car guy and I do have some skills... I don't want to deal with a carburetor. I just want to turn the key and have it work. Also I understand the efi or TBI really will increase fuel economy.
Old Jan 7, 2024 | 07:06 PM
85e150's Avatar
85e150
1 bbl carb is pretty simple. And cheap.
cullynhaas
Sep 2, 2023 11:26 PM
jackietreehorn
22
Jul 12, 2023 04:48 PM
51f3ford
18
Jul 1, 2019 09:06 PM
Quick444
Aug 27, 2018 07:34 AM
IDIDieselJohn
36
Aug 29, 2010 12:44 PM
