Sponsored by: Real Truck
esof help
Old Dec 30, 2023 | 01:30 PM
the beast 1's Avatar
the beast 1
esof help
I know this subject has been posted a lot. I have a 2008 f250 super duty with the 6.8 v10. my esof will not engage have to lock the hubs in to have 4wheel drive. Do not have access to a mighty
vac pump at this time. I had checked vacuum lines to hubs had one bad fixed it still no automatic. I have vacuum. at the canister and the line going into the phv.. I ran 12 volts to the center pin and grounded each other pins. Solenoid clicked each time. I then connected the vacuum from the engine to the hub lines and it would lock into 4 wheel. Shut truck off and the stayed locked in. Had to turn from auto to lock and back then they would unlock. Would that indicate the hub seals are good. Any suggestions would be appreciated. Thanks
Old Dec 30, 2023 | 08:28 PM
eddiemeixell's Avatar
eddiemeixell
4wd High
Your hub seals should be good if they lock. As far as staying locked, my guess is either your hubs are getting sticky or are wearing out. I would like to find a lube for mine. I live in MN so it will have to work in cold temps.
Old Dec 30, 2023 | 09:07 PM
00t444e's Avatar
00t444e
I wouldn't bother with getting the auto hubs working, it is a junk system that I would never want to rely on. Just lock them manually.
Old Dec 30, 2023 | 10:19 PM
Lance Helmert's Avatar
Lance Helmert
Try taking them apart. Clean them and lightly grease, I put pipe plugs out by the wheels and removed the solenoid and vacuum lines. I lock my hubs in the fall and unlock them in spring.
Special Ed
Feb 19, 2013 07:45 PM
Younork
Feb 17, 2012 09:28 PM
vtmdsm25
Oct 22, 2005 11:11 PM
getterdun
Jul 29, 2004 08:49 AM
