Coyote swap Troubleshooting
Old Dec 29, 2023 | 02:05 PM
Falcon57's Avatar
Falcon57
Trailering
Hello,
Recently started my coyote in 1956 F100.
Have bad noice from engine, any ideas what this can be?
We noticed crack in valve cover if this can be the problem perhaps.
Thanks in advance.
Old Dec 29, 2023 | 02:14 PM
EBEAR's Avatar
EBEAR
Sounds like an exhaust leak at the manifold . Single cyl noise .
Old Dec 29, 2023 | 02:23 PM
Falcon57's Avatar
Falcon57
Trailering
Thanks for the suggestion. Yes we first thought that as well, but we worked with the headers and double-checked that they were 100%.
Old Dec 29, 2023 | 02:42 PM
Falcon57's Avatar
Falcon57
Trailering
We also did a diagnostic with the following readouts:
P0103:00-E8 Air mass A circuit high input
P0113:00-E8 Inlet air temperature sensor 1 circuit high
Old Jan 6, 2024 | 08:43 AM
Jetfixer-6's Avatar
Jetfixer-6
I hope I'm wrong but it sounds more expensive than an exhaust leak. What's the background on the Coyote purchase? Mine threw the mass air code at first until I had the entire intake and aircleaner assembled with the MAF in the correct location. Have you any updates to your situation?
Old Jan 6, 2024 | 10:49 AM
Falcon57's Avatar
Falcon57
Trailering
After a lot of troubleshooting we found the exhaust leak so it is sorted.
Now it is only a rough idle we are working on. 2500-4000rpm no worries but idle is very rough and it dies if you leave the throttle.
Old Jan 6, 2024 | 10:53 AM
Jetfixer-6's Avatar
Jetfixer-6
It will until you have the intake inlet tube configured, lemme guess fire it up and RPM's are way up there for a couple of secs, then it comes back down then dies?
Old Jan 6, 2024 | 01:41 PM
Falcon57's Avatar
Falcon57
Trailering
Tried with everything inlet tube / air filter installed but same result. Checked MAF sensor as well.
what do you mean with configured? Tuned?
Old Jan 6, 2024 | 02:41 PM
Falcon57's Avatar
Falcon57
Trailering
Should say that i have the no tune air intake system from PBH.
Old Jan 7, 2024 | 07:50 AM
Jetfixer-6's Avatar
Jetfixer-6
Configured meaning longer tube with the air filter installed. Once I had my MAF located correctly it ran perfect. I had to move it further upstream and to the other side of the intake tube at the advice of the Ford Tech at Ford performance. I used their control pack. His thought with my first set up was the MAF was to close too the throttle body.
Old Jan 7, 2024 | 08:51 AM
Falcon57's Avatar
Falcon57
Trailering
Alright, i understand!
current setup in photo below. So you think it could help with longer intake tube and put the sensor on the other side?
Old Jan 8, 2024 | 08:05 AM
Jetfixer-6's Avatar
Jetfixer-6
I would think your current configuration would be more than adequate. Is the MAF sensor new? Do you have a tuner in your area? They can most likely correct your issue. Where did you get your Coyote from?
Old Jan 9, 2024 | 02:51 PM
Falcon57's Avatar
Falcon57
Trailering
We rotated the tube a little bit so the sensor got a little bit further away and it seemed to help. Ran a bit better but still rough. Not sure if it gets the correct 55psi fuel pressure so trying to future out how to set the edelbrock regulator on exactly 55.
A good tune probably Will do wonders as well, did you do Lund racing?
nice swap btw and thanks for all the help.
Old Jan 9, 2024 | 04:15 PM
Jetfixer-6's Avatar
Jetfixer-6
As far as fuel pressure needing to be right at 55 mine was always at 58psi. I used the Corvette C5 filter regulator combination and it automatically regulates at 58 PSI.
With the Ford Racing control pack you don't need a tune, it's Plug and Play, it also came with a preloaded tune which gave it a small bump in horsepower. I never had to do anything but connect the five wires and it ran perfect, after I adjusted the MAF location.
Old Jan 9, 2024 | 06:56 PM
seaves46's Avatar
seaves46
Make 100% sure you have no vacuum leaks .
