Help installing a shift collar
Old Dec 27, 2023 | 03:01 PM
Moonlightford's Avatar
Moonlightford
1965 F 100.
4 speed, granny low, 240 6 cylinder
Members,
My truck has a 4 speed on the floor, it was born with a 3 on the tree.
The change was made way before I got it.
my question, I bought the Correct shift collar. Is it as simple as pulling the wheel, removing the signal switch and installing it?
Or are there any unforeseen issues I need special tools and patience! for?
Old Dec 27, 2023 | 06:03 PM
FarmMotorSports's Avatar
FarmMotorSports
A blank collar can be installed NBD. As a caveat to that, be prepared to completely pull the column and remove the shift tube and arms. I'm not sure that those parts will prevent installation of a non shift collar, but it would be better if, they were removed. The parts can be retained as original parts or sold to people in need of a usable tube and arms. The floor shift collar is retained by two small screws thru the bearing plate, they may need to be drilled.
Just my opinion, but see what others have to say.
Old Dec 27, 2023 | 08:07 PM
Moonlightford
if removing the column is necessary I should consider replacing the upper and lower bearings. Plus?
Old Dec 28, 2023 | 02:38 PM
FarmMotorSports
Having seen "some" of what is being offered for replacements. I would save and lube the originals if possible... Inspect the turn signal canceling cams and replace if suspect for failure due to cracks and age embrittling the plastic.
Ibex
1966 - 1977 Early Broncos
Jan 5, 2024 06:09 PM
Telestar
Jun 6, 2023 04:51 PM
1954wrecker
Oct 24, 2018 08:48 AM
RDON
Nov 9, 2009 11:44 AM
sancochojoe
Apr 16, 2005 07:54 AM
