steering column for 77 f150
Old Dec 24, 2023 | 11:16 PM
tirebuilder's Avatar
tirebuilder
2nd Gear
ive googled this and come up with nothing but is their a video or any other information on reubilding the steering column for a 77 f150? Are their any columns from other years that would work or would an aftermarket universal one from like summit or jegs or lms be a good idea? thanks in advance. be gentle, im a newbie
Old Dec 25, 2023 | 01:58 AM
NM76F150's Avatar
NM76F150
The column is extremely easy to rebuild. The hardest part is feeding the wires through if you get a new turn signal switch, which I recommend. Get your lower bearing here, night a day difference from the replacement junk sold elsewhere.
https://drbfab.com/products/all-meta...-76-79-broncos
You can find some pictures I posted here.
https://www.ford-trucks.com/forums/1...l#post21042640
Old Dec 25, 2023 | 06:41 AM
jflem's Avatar
jflem
Welcome tirebuilder to FTE. X2 on the easy to rebuild.
Old Dec 25, 2023 | 07:45 AM
NM76F150's Avatar
NM76F150
Just remembered this. Couldn’t find part 1…..
Old Dec 26, 2023 | 02:54 AM
tirebuilder
2nd Gear
thanks, i sure appreciate it
Old Dec 26, 2023 | 08:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Tape the end wires of the TS switch together and add one extra long wire to help pull the new switch wire bundle (taped together) back down the tube.
Nate92
Jun 20, 2019 04:50 AM
blockheadbob
Jul 17, 2005 03:11 PM
David Campione
Oct 8, 1999 01:55 PM
