2024 SD Fog Light problem?
Old Dec 24, 2023 | 07:49 AM
Mikdor1's Avatar
Mikdor1
6th Gear
I happened to notice on my security camera when I was pulling my truck into the garage as I was positioning it when I turned left the left fog light was on. When I turned right the left one turned off and the right one turned on. Both didn't come on when wheel was straight. Is this something new or do I have a problem?
Old Dec 24, 2023 | 07:52 AM
dpbrown02's Avatar
dpbrown02
They’re used for cornering lights to help illuminate the area you are turning into when driving at low speed. It’s normal and a lot of vehicles have them now!
Old Dec 24, 2023 | 08:00 AM
Erie660's Avatar
Erie660
Thanks for the info. My 2024 does the same thing.
Old Dec 24, 2023 | 08:01 AM
PonderosaPilatus's Avatar
PonderosaPilatus
Yep, turns on when you turn.
Old Dec 24, 2023 | 08:09 AM
Mikdor1's Avatar
Mikdor1
6th Gear
That's good to know! Thanks for the responses. Glad we have this forum !😃
Old Dec 24, 2023 | 08:35 AM
srkr's Avatar
srkr
2023 does the same. Lariat Ultimate.
Old Dec 24, 2023 | 12:03 PM
Rwhjr's Avatar
Rwhjr
I leave fogs on so mine don’t seem to switch on/off by themselves
But i did not know this and I thought my dads truck had an issue lol
ill look at it a second time and see if its because he’s leaving them off and they’re automatically coming on as he turns?
Old Jan 18, 2024 | 01:47 PM
Rangervx's Avatar
Rangervx
if the fog lights are off, they are steering sensitive and whichever side you are turning, that lamp will illuminate...if your fog lights are on, well they are both on of course.
Old Jan 18, 2024 | 02:24 PM
99powerstrokedF250's Avatar
99powerstrokedF250
As stated above, it is a feature to help illuminate the area you're turning into at low speeds (think off-roading after dark, which brings its own possible dangers) when your brights are on. It is a normal function on newer vehicles. I leave my fogs switched on, so I only see them doing this with the brights on.
Old Jan 18, 2024 | 02:25 PM
99powerstrokedF250
Yes, any time the fog lights are off they will illuminate during a low-speed turn. So brights on, they'll do this. Fog lights switched off, they'll do this.
Old Jan 18, 2024 | 04:19 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I almost started a thread on this the other day. I saw my truck doing this from the driver seat the other night and it weirded me out. I’ve never heard of this before.
Is there any way to disable this feature? I drive backroads, and disabling this will keep another 200 on/off cycles a day of the fog lights…which can’t be good for them.
Old Jan 18, 2024 | 07:54 PM
Fox-BLUE1's Avatar
Fox-BLUE1
I checked the manual and did not see a way to disable it. It appears to be disabled above 25mph though per the manual. I would think you could use forscan to disable it possibly?
Old Jan 18, 2024 | 08:14 PM
chukeeee's Avatar
chukeeee
Just leave the fogs on all the time, and do the “bambi mode” change with forscan
Old Jan 19, 2024 | 02:35 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thats the plan, just haven’t had time to do it yet.
Old Jan 19, 2024 | 01:15 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Saw this while I was making some changes in Forscan. I was too chicken to change it. Plus, I had already enabled Bambi mode, so I wasn't gonna change that back to stock just to try this...
