Steering help
Old Dec 22, 2023 | 10:16 PM
antwan181's Avatar
antwan181
Steering help
Hey y'all,
im hoping you could help me out. I got a 2017 f350, that at mostly highway speeds the steering tends to get real sloppy. If I stop and wiggle the wheel, the steering feels tight, but when I’m at highway speeds, i can get a good swoosh side to side on the wheel and it even causes the service advancetrac light to come on. Any help is greatly appreciated.
Old Dec 22, 2023 | 10:22 PM
4wd6.7L's Avatar
4wd6.7L
Sloppy as in there is play or a dead zone in the steering?
Old Dec 22, 2023 | 10:27 PM
antwan181's Avatar
antwan181
define dead zone if you could please
Old Dec 22, 2023 | 10:35 PM
4wd6.7L's Avatar
4wd6.7L
Play and dead zone, at least to me, are the same, meaning an area in the steering that is non responsive. You turn the steering wheel and there is no movement at the wheels.
Do you have adaptive steering?
Old Dec 22, 2023 | 10:53 PM
antwan181's Avatar
antwan181
then yes, there is play/dead zones. I’d say the play is when I’m going straight, i can swoosh it side to side and you really notice the dead zone when your going around a curve, most of the time the service advance trac light comes on around the curves
no i do not have adaptive cruise
Old Dec 22, 2023 | 11:25 PM
muisejt's Avatar
muisejt
something in the steering is worn out, check the pitman arm, drag link, tie rod
BOSS 379's Avatar
BOSS 379
He is asking if you have adaptive steering, which adjusts magnitude of power assist based on speed.
Old Dec 23, 2023 | 04:55 AM
B-ManFX4's Avatar
B-ManFX4
Is your truck 4x4?
Old Dec 23, 2023 | 06:33 AM
shawnee1's Avatar
shawnee1
Adaptive steering changes the steering ratio based on speed. It does not adjust the magnitude of power assist. I mention this in case the OP's truck has adaptive steering.
Old Dec 23, 2023 | 06:54 AM
antwan181's Avatar
antwan181
i don’t have adaptive steering
Old Dec 23, 2023 | 06:55 AM
antwan181's Avatar
antwan181
Originally Posted by B-ManFX4
Is your truck 4x4?
yes sir it is
Old Dec 23, 2023 | 09:15 AM
67_4_ME's Avatar
67_4_ME
Time to get under the truck with a pry bar and start checking all the moving parts. If you're unable to do that, you'll need to find a shop you trust and let them take a look at it.
Old Dec 23, 2023 | 10:09 AM
Mike Bartlett's Avatar
Mike Bartlett
Start with the cheap/easy stuff first. Check tire wear and pressure also rotate to rear to see if any change. As suggested any loose front suspension components, ball joints as well, jack up the front and see if wheels wobble from side to side. If nothing turns up with the above bring to a good alignment shop one that does big trucks not small cars. Tell them your issue they should be able to help.
Good luck…
Mike
Old Dec 23, 2023 | 10:37 AM
antwan181's Avatar
antwan181
I’m going to check with a pry bar, that’s a good suggestion thanks. So far it’s been at 2 different shops and they keep focusing on the advancetrac system and they’re telling me the front end looks good and it’s just something with the system itself… then i gave in and bought it to 2 different ford dealers. Both of them left it sitting in their lot untouched for over a week meanwhile i had an “appointment”. If i can’t figure this out im honestly thinking of going back to ram/ Cummins. Customer service with ford so far really hasn’t been a pleasant experience.
Old Dec 23, 2023 | 12:17 PM
4wd6.7L's Avatar
4wd6.7L
The play in the steering and the AdvanceTrac should be diagnosed separately. Not sure why they are prioritizing the AdvanceTrac if the steering play is your main concern. I would think there might be a code stored associated with the AdvanceTrac fault. A good alignment shop may be another option for diagnosing the steering play. If you're able to get it off the ground and something is wore out bad enough finding it yourself could be easy. You could also try with it on the ground (that's how I would start), use a helper or a camera setup, wiggle the steering wheel back and forth while looking for excessive play in the steering components.
