Fuel tank assembly
Old Feb 16, 2024 | 12:22 AM
66F250_4x4's Avatar
66F250_4x4
Originally Posted by BarnieTrk
Ohmthis or anyone,
Do you know of a location where to purchase some 5/8" OD Nickel/Copper tubing?
Back on post #3, Wayne posted a pic of his fuel line plumbing with looks like some 5/8" OD soft copper tubing.... it looks good, but maybe not for long if it's going to crack..... 5/8" OD steel or SS tubing can be tough to run through a tube bender.
- BarnieTrk
Hey,
That's 3/8 nicopp. I purchased that material via Amazon, but I would recommend trying The Stop Shop based on reviews I later heard that aligned with my experience.
5/8" is pretty large. I've seen 1/2" nicopp. I believe our trucks were delivered with 5/16" fuel lines. I have a 460 and bumped up to 3/8 because I felt it may have been starving at times, and some research suggested that could be the case.
Old Feb 16, 2024 | 04:45 AM
Crop Duster's Avatar
Crop Duster
Originally Posted by ADELEANDRE
I wanted to use a very small piece of copper to make an elbow fitting with a 1/2 nut to screw to the tank (15 cm long) and then put braided hose up to the fuel pump
Your cheapest way out if you can find one of these in country is a line with fittings already on it, then bend it to fit. Brake Line - Universal Steel Hydraulic 5/16" BK 8131235 | Buy Online - NAPA Auto Parts (napaonline.com)
A simple tube bender is all you need to make a line to get under the cab. Remember all the hard line for fuel is double flared just like the brake lines. Except in the case of AN line which uses a backup sleave. If you have to use rubber line because of where you are, use AN lines and fittings you should be able to get those anywhere because that is the standard for almost all aircraft. There are adapters to go from 5/16 inverted flare to AN.
Old Feb 17, 2024 | 08:54 AM
BarnieTrk's Avatar
BarnieTrk
Originally Posted by 66F250_4x4
Hey,
That's 3/8 nicopp.
My mistake, Wayne. My eyes were deceiving me.
5/8" OD is typically called 1/2" pipe......which is what the ID measures.
Depending on how high & how long you spin the 460, such as drag racing events, would determine if it runs out of fuel or not. A fuel log at the carb is helpful to this end as well.
BarnieTrk
Old Feb 20, 2024 | 04:24 PM
Ohmthis's Avatar
Ohmthis
BarnieTrk
3/8” is plenty for a street strip engine of almost any size. That will support 500 NA hp. I have used the stop shop as well and I’ve received excellent parts. The stop shop should have the fittings as well.
Old Feb 20, 2024 | 04:29 PM
Ohmthis's Avatar
Ohmthis
Just a quick search found this. I have no affiliation with them. I am just a happy customer.
https://www.thestopshop.com/collecti...products/bl0cn
Old Feb 21, 2024 | 04:06 AM
benbuilder's Avatar
benbuilder
Fuel line
If you need that fuel line, I have a couple of them OEM. Reach out to me. if not good luck ok also
auldvancar
Jan 31, 2022 08:12 PM
victoryvan
Jul 17, 2020 11:10 AM
blue76
Jul 2, 2016 06:16 PM
03silverTJ
May 12, 2016 01:34 AM
