Dana44?
Old Nov 23, 2003 | 04:20 AM
BLaCkSiLo's Avatar
BLaCkSiLo
Question Dana44?
i have a 1984 ford f-250 with a 460, 4 speed and a standard cab, i was wondering what rear end i have in my truck, could it perhaps be a dana44? any help would be appreciated,
Thanks,
~BLaCkSiLo
Old Nov 23, 2003 | 07:32 AM
bobcf's Avatar
bobcf
rear would be more like the ford 10.25 full floating. a danna 44 could be your front drive axle. My 92 has a 44 molded im the housing.
Bob
Old Nov 23, 2003 | 01:49 PM
BLaCkSiLo's Avatar
BLaCkSiLo
thanks for the info but a dana44 out front with the Ford IFS?
Old Nov 23, 2003 | 04:31 PM
Txquadhunter24's Avatar
Txquadhunter24
Out front it's the D44 TTB Twin traction beam.
Old Nov 25, 2003 | 09:31 PM
85351ho's Avatar
85351ho
they didnt use the sterling until 85
Old Nov 26, 2003 | 12:19 AM
hoxiii's Avatar
hoxiii
it's probably a dana 60. If you've ever pulled a Dana 44 down you'd be counting your lucky stars not to have it as a rear diff. I see it as a good axle for intermittent use or very light duty use. I just rebuilt a couple 9"s and then pulled a 44 down to inspect it. After messing with the 9"s I was almost afraid to handle the parts of the 44, they looked so fragile and insignificant in comparison. After doing this it just amazed me that ford and gm both offered the 44 as a rear diff in full-size trucks and that people actually ordered it.
Justin
Old Dec 2, 2003 | 01:25 AM
BLaCkSiLo's Avatar
BLaCkSiLo
so...its probabley a dana60 out back...and a dana44ttb out front?
Old Dec 2, 2003 | 04:08 PM
78f3504x4's Avatar
78f3504x4
Most likely a Dana 60 semi-floater. I know Ford had the Dana 70 Full-floater as an option though.
Old Dec 3, 2003 | 12:35 AM
BLaCkSiLo's Avatar
BLaCkSiLo
well, i just did a complete diff replacement on a 77 f-250 and my axles come out the same exact way that the 77 does.... i was told its a dana60 but is there anyplace i can go to really see for sure?
Old Mar 1, 2004 | 01:28 AM
bmiller529's Avatar
bmiller529
80-9? F250s mostly in rear are 10.25 front isnt 44 or 60....ford put dana 50 ttb in these
