Track bar relocation bracket
Old Dec 14, 2023 | 06:32 PM
WXboy's Avatar
WXboy
At what amount of lift do you guys think the track bar relocation bracket is a must-have? Is it thought that there's a certain point where it's just necessary? I did the smallest level kit I could get at 1.5 inches.
Old Dec 14, 2023 | 07:09 PM
4wd6.7L's Avatar
4wd6.7L
You can measure to see how close to center your front axle currently sits and if it's centered, or close to it, then you don't need the bracket.
Old Dec 14, 2023 | 07:17 PM
JayCarver's Avatar
JayCarver
At 1.5” your absolutely fine.
Old Dec 14, 2023 | 10:17 PM
morehouse7's Avatar
morehouse7
If you want the axle perfectly centered, just get an adjustable track bar and skip the drop bracket.
Old Dec 14, 2023 | 11:07 PM
Joe T's Avatar
Joe T
Yeah you will need an adjustable track bar at 1.5” if you want it perfect. Maybe not though if its a heavily optioned diesel with 5200 springs.
The drop bracket is ok at 2 inches, probably works fine at 2.5” too.
Old Dec 15, 2023 | 07:59 AM
WXboy's Avatar
WXboy
Thanks guys. The axle is off center but it's not horrible. I think I'll just wait until the track bar bushings are ready to be replaced and then thrown an adjustable bar in there.
Reason I asked though is that I had some tires and wheels mounted on the truck Tuesday and ever since then the truck pulls to the left just a little. The wheels are +12 offset so nothing crazy. The tires are 33x12.50 and they're an aggressive A/T. Again, nothing crazy. But it pulls left some now, and it wasn't doing that on the stock wheels/tires. I'm just trying to determine why the truck is showing a tendency to dive left. It's starting to look like it's the tires. But I just thought maybe it's a combo of the wider tires and axle being slightly off-center to the left now.
Old Dec 15, 2023 | 08:40 AM
jimzpsd's Avatar
jimzpsd
Check the tire air pressure, front left could be lower than the right....this will cause it to pull left. I doubt it is a left brake caliper hung up, if it was it would have been doing this before hand.
Old Dec 15, 2023 | 12:34 PM
speakerfritz's Avatar
speakerfritz
everyones comments are valid....
but also....if you have the plow packge....your springs put you higher 3/4 to 1", so if you add 1.5, theres a new number to think about.
see if you can notice a difference on axle position left side vs right
Old Dec 15, 2023 | 07:30 PM
honda250xtitan's Avatar
honda250xtitan
track bar bracket (with perfectly fine OEM track bar and the ball joints aren't clapped out) > then adjustable track bar.
maintains OEM geometry, less money, same result. Yes i've done both. was chasing a clunk, thought it was the OEM track bar.
some adjustable track bars are too long even for an 1.5" kit anyways.
Old Dec 17, 2023 | 06:42 AM
B-ManFX4's Avatar
B-ManFX4
PMF adjustable trackbar. Centered my axle perfectly - way heavier duty than the OEM unit.
Old Dec 17, 2023 | 07:48 AM
Joe T's Avatar
Joe T
I have a 1.5 kit on my heavy azz king ranch 6.7 (2017) and your only real option is an adjustable track bar. I got one off of Amazon, forget the brand but its set all the way tight and works as advertised for a 1.5” + lift.
The axle was off center without it. I wanted the RC coils specifically with 1.5” and this the trackbar is a mod that I felt was necessary.
It drives great.
I do agree with your assessment if you have a tight newer front end just go with the bracket if you do a 2” or 2.5” level. They may be good up to 3 inches?
Old Dec 12, 2025 | 11:32 AM
ruphianh's Avatar
ruphianh
definitely go with an adjustable track- will help with centering axle, improve bump steer as the track bar and drag link stay closer in angle. There is no need to worry about threads. Threads exist everywhere already and the track bars are no different.
Old Dec 13, 2025 | 07:09 AM
B-ManFX4's Avatar
B-ManFX4
Rotate the fronts to the rear and see if the pull goes away. If it does you have a tire exhibiting "radial pull".
Old Dec 13, 2025 | 01:43 PM
honda250xtitan
2 year old thread fellas
Old Dec 14, 2025 | 07:34 AM
Midwest87's Avatar
Midwest87
Muh trucks 8 years old.
No track bar for you.
