VIN decode/front axle info
Old Dec 13, 2023 | 09:47 AM
CrazyKarl's Avatar
CrazyKarl
2nd Gear
I could use some help decoding my vin to find my front differential Information.
2005 F150 XL 4.6l V8 with 4x4
Vin - 1FTRX14W95KC83193
# at bottom of driver door sticker - 4U5A-1532-AA(TLU)
Old Dec 13, 2023 | 11:48 AM
TA455HO's Avatar
TA455HO
Lead Gopher
@NumberDummy hasn't logged on for a while now. Even his books didn't go to 2005. Mine don't either. This forum is for 1961-1966 trucks. You might see if your fellow era truck owners can help at the below forum section for 2004-2008 F150s.
2004 - 2008 F150 - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Dec 13, 2023 | 02:51 PM
85e150's Avatar
85e150
Post moved.
For the 17 digit VIN, you can decode those through several on-line decoders such as:
https://www.blueovaltrucks.com/tech/...-VIN-Guide.pdf
You can go through that but it's quite tedious and after all that you will not have the front axle info as it is not included in the VIN.
It is listed on your white plastic certification label where the axle codes are towards the bottom right side.
Your axle should also have a tag on it, affixed via one of the bolts holding the cover on.
And since you are now in this forum, someone familiar with these might be by with the answer.
What are you trying to determine about the differential?
Old Dec 14, 2023 | 07:08 AM
CrazyKarl's Avatar
CrazyKarl
2nd Gear
The diff is going out on the driver's side with play/slop and I'm trying to figure out Wich one I need so i can start pricing used and/or know what rebuild kit to get.
Thank all of you for any input or help, my mistake for posting in the wrong category.
Old Dec 16, 2023 | 12:20 PM
projectSHO89's Avatar
projectSHO89
Axle information is not encoded in the VIN. It's on the door jamb label instead, under the word "AXLE.
Unless someone has access to to as-built or Monroney data, the VIN isn't going to help.
encore243
Large Truck
Dec 17, 2022 05:29 PM
classictruckman
21
Sep 4, 2016 04:35 PM
61 uni
Oct 7, 2012 08:20 PM
seth_85
Jan 23, 2006 03:46 PM
N7HJ
Jun 16, 2004 09:56 PM
