Bell Housing Pattern
Old Nov 23, 2003 | 12:20 AM
jaroh's Avatar
jaroh
Hello,
I have been reading through all these and got to page 10 and gave up. I only have one simple question.
Will the bell housing from a t -19 300 I-6 bolt up to a 302. I am trying to figure out if I am willing to go through a c 4 auto to manual tranny swap on my 73 bronco.
Thanks, Duane
Old Nov 23, 2003 | 04:44 PM
Txquadhunter24's Avatar
Txquadhunter24
The I6 uses the same bolt pattern as the small block 302/351W. You'll need a 302 flywheel though
Old Nov 24, 2003 | 12:07 AM
jaroh's Avatar
jaroh
Thanks for the information. I am still trying to decide if I want to go through the hassle of changing from a c-4 to a t-19. The hard part is spending the cash for something I might not like. I guess I could still go back to the c-4 if I don't like it.
Here is another question maybe somebody might an idea about.
The t-19 has a np 208 hooked up to it. Do you think it will fit into an early bronco?
Thanks again.
Duane
Old Nov 24, 2003 | 09:20 AM
millertime300's Avatar
millertime300
I don't know about the second question, I would just like to assure you that for only use two bolt patterns big and small block the 6 is the same as the 260, 302 351 (not M)
