Engine Identification
Old Nov 22, 2003 | 10:01 PM
allmyfords's Avatar
allmyfords
Post Engine Identification
I just purchased a 1989 Bronco with the 5.0 EFI engine. The engine appears not to be original and I don't have a clue how to find out what year engine is in the truck.
I believe the engine is not original for the following reasons:
1) Water pump for a 1989 Bronco 5.0 won't fit my truck.
2) Spark plugs are very long reach (Autolite #2546) which cross over to AC# R45NTSE. Not the normal R43TS plugs spec'd for the 89 Bronco 5.0
3) Knock Sensor is located on the intake manifold, dead center as far back on the manifold as possible in a position where no normal human can see it or get to it for removal.
Any help in identifying this engine would be greatly appreciated.
Old Nov 23, 2003 | 06:33 PM
steve83's Avatar
steve83
That's the normal location for the knock sensor, but check here.
Old Nov 23, 2003 | 07:02 PM
abn1975's Avatar
abn1975
I'm having the same problem with my 94 F-150. I have bought books and looked all over the engine but still can't figure out where the ID plate for the engine would be. My intake says "5.0 EFI" with date stampings of 1994, but the firing order is that of a 351 or 302HO. I had thought maybe since my truck was assembled in November of 94 the plant had used the 1995 5.0 engine with the 351's firing order but have yet to find a 95 date stamping. If I could find the ID plate it sure would solve a lot of my problems. Any help would be greatly appreciated.
Old Nov 23, 2003 | 07:29 PM
steve83's Avatar
steve83
It's not surprising that your '94 would have a '95 engine - they had to make the change sometime in '94. Just start thinking of it as a '95 engine and it should make more sense.
Old Nov 23, 2003 | 07:44 PM
abn1975's Avatar
abn1975
I wish it was that easy but if it is a 95 then why do all the date stampings say 94? The ID plate is probably the only thing I really can trust. If only I could figure out where it is....
Old Nov 23, 2003 | 07:51 PM
steve83's Avatar
steve83
Because it was built in the calendar year of '94. But obviously, it was built to the '95 MODEL year specs.
Old Nov 23, 2003 | 07:55 PM
abn1975's Avatar
abn1975
So...you have no idea where the ID plate is?
Old Feb 15, 2006 | 09:24 PM
hunter0307's Avatar
hunter0307
your engine is manufactured too the 1995 model year specs,it is in all accounts a 1995,i have a 11/94 ford f150 XLY 4x4,it is a 1995 302HO,check your firing order,if the first 2 are 1,5,you have a 95 or up 302HO
hunter0307's Avatar
hunter0307
not XLY,XLT lol
Old Feb 15, 2006 | 09:39 PM
brosko80's Avatar
brosko80
someone tell him where the id plate is!
Old Feb 15, 2006 | 09:41 PM
hunter0307's Avatar
hunter0307
his message is 3 years old ,lmao,did'nt notice till after i posted lol
Old Feb 15, 2006 | 09:49 PM
brosko80's Avatar
brosko80
ha ha neither did I I guess by now he knows which motor it is. ha ha
Old Feb 25, 2006 | 10:12 AM
Ford_for_Brains's Avatar
Ford_for_Brains
or sold it out of frustration (lmao)
Old Jan 3, 2007 | 12:23 PM
abn1975's Avatar
abn1975
Wow!!!
Thanks for getting to the ID plate issue, everyone. You might, however, want to look at the truck pics in my gallery NOW and see how I got around the problem of ID'ing this engine. It's the expensive way but I'm happy.
AIRBORNE, ALL THE WAY!
SSG Stephen A. Green
Paratrooper, US Army Intelligence
Special United States Liaison Adviser to Korea
"38 kills and STILL no joy"
Old Jan 3, 2007 | 12:31 PM
abn1975's Avatar
abn1975
DANG!!! Ok, fellas. I knew it was going to be a pain in the butt if I changed my screen-name. My projects are now under my Booneyrat name but here's the links. C'mon...you know you wanna see what I've been doing...
https://www.ford-trucks.com/user_gal...&albumid=13597
