Ticking noise comming from engine
Old Nov 22, 2003 | 09:49 PM
Fastboy22's Avatar
Fastboy22
Question Ticking noise comming from engine
I have a ticking noise comming from my engine and i just cant figure out what it is??? I have re-adjusted the timing to factory specification but still it ticks, Any help would be greatly appreciated.
Old Nov 22, 2003 | 10:51 PM
Fastboy22's Avatar
Fastboy22
Also it has a very irratic idle, especially in the cold. the high idle will come on but sometimes it doesnt, and other times it will idle fine but then drop to about 400rpm and run really rough and almost stall.
Old Nov 22, 2003 | 11:47 PM
motorheadmach1's Avatar
motorheadmach1
if you tell us what year truck and what engine you have it will help us help you. right now im thinking somethign electronic as far as relays but im not sure if your truck poseses such things.
Old Nov 22, 2003 | 11:48 PM
locknkey's Avatar
locknkey
What kind of engine is it and is it EFI? Year model? Carb?
Old Nov 23, 2003 | 03:46 PM
f100guy's Avatar
f100guy
that might be the egr valve leaking or something i have heard them ticking before and it does sound like the valves. that might even cause the wierd idleing too
Old Nov 23, 2003 | 03:48 PM
f100guy's Avatar
f100guy
either that or you have some bad spark plug wires arcing on th block making the noise or something but i doubt that
Old Nov 23, 2003 | 05:13 PM
Timken's Avatar
Timken
You may also have a broken piston skirt like I had in a 302 10years ago, sounds a lifter ticking that won't pump up ,only a little faster tick. A buddy of mine tore down his 302 to do a rebuild just because he had a lot of miles on mtr. He told me half of the piston skirts were in the oil pan, but the mtr still sounded fine.
Old Nov 23, 2003 | 08:06 PM
motorheadmach1
if its an efi motor i would check the egr valve, the idle air control/ air bypass valve and maybe the fuel pump relay.
Old Nov 23, 2003 | 11:23 PM
Fastboy22's Avatar
Fastboy22
Its a 1986 ford F150 300 six with a carb, hope this helps narrow it down. Could it be anything to do with the water pump as that has just started squeaking??
Old Nov 24, 2003 | 05:25 AM
locknkey's Avatar
locknkey
If its squeaking....The water pump bearing could be going bad, but unlikely as its a sealed bearing again, it all could be a cut belt thats frayed and hiting one of the brackets as its moving along - round an round...a belt would squeak too. Look at it closely, try to locate where in the area its coming from......
Old Nov 24, 2003 | 05:08 PM
Fastboy22's Avatar
Fastboy22
Its comming directly from the water pump, the fan also has alot of play in it in every direction and its even worse when the belt is off.
Old Nov 24, 2003 | 08:26 PM
locknkey's Avatar
locknkey
Fan clutch needs replacing...my last one cost $80.00 new...cools real good in summer time, and is quiet.
Old Nov 24, 2003 | 09:09 PM
bremen242's Avatar
bremen242
Look at see if hub where the belts ride is loose, if that is the case, that the water pump bearing is shot. if the fan moves and not the hub, i'd say it was the clutch
but my guess is your water pump is shot, but I doubt that is causing your problem.
Check to see if the ticking is coming from the carb. Once it warms up, one of the solenoids on the carb will make a clicking/ticking noise, that's normal. My 84, the solenoid was going bad, and it would click when it felt like it. I think it controls the mixture @ idle, so that could be causing the trouble.
the feedback system on the mid 80s 300s are the worst ever designed.
Old Nov 25, 2003 | 06:31 PM
MANFRED's Avatar
MANFRED
Does the ticking increase in tempo as you rev the engine??
Maybe a valve tap.
Does the Truck leak oil??
Check the oil level. Mine taps when It goes low.
Manfred
'86 F150
Old Nov 26, 2003 | 01:06 PM
howler's Avatar
howler
On my 83' 5.8 (351ci) there are relays on the drivers side valve cover that tick just like a lifter...
