Sponsored by: Auxito
Hidden Sensor
Old Dec 5, 2023 | 04:36 PM
Larryjr03's Avatar
Larryjr03
Hidden Sensor
2003 Ford F150, Lariat with 5.4 L Engine. Where in the world is the Ambient Temperature Sensor located ? I keep reading MAY be behind the grille ? I looked there, I don't see squat ! Any help appreciated. P.S. Someone at my favorite auto parts store said maybe near the Airbox ? Thanks all.
Old Dec 5, 2023 | 07:34 PM
Jon Freeman's Avatar
Jon Freeman
Maybe this will help. Not 100% sure it applies to your model.
https://trucksauthority.com/how-to-r...-on-ford-f150/
Old Dec 6, 2023 | 07:59 AM
projectSHO89's Avatar
projectSHO89
An '03 will have an AAT sensor ONLY if it is equipped with the EATC climate control system. If you have a manual climate control, that sensor is not going to be present. I would assume that a Lariat trim did come with the EATC.
BTW, do not confuse the AAT with the IAT (Intake Air Temp) sensor.
Here's where the EVTM says the AAT is located: You may have to remove the radiator sight shield to see it mounted up high just to the passenger side of the center of the radiator opening.
Old Dec 7, 2023 | 04:45 PM
Larryjr03's Avatar
Larryjr03
Hidden Sensor
Thank you very much ! I will seek out this weekend.
Old Dec 8, 2023 | 10:41 AM
Hit Man X's Avatar
Hit Man X
My 2001 Lariat Screw does not have the ETAC, just manual. But it does have that overhead console with exterior temperature display and direction.
Maybe it will help too.
Old Dec 8, 2023 | 12:56 PM
projectSHO89
The EATC wasn't offered for the 2001 F150 so yours is going to be different from the OP's 2003.
According to the manual, yours for the overhead console would be located in a similar position, just to the driver's side instead.
Old Dec 8, 2023 | 01:02 PM
Hit Man X's Avatar
Hit Man X
Ah. Interesting, always good information from you.
Thanks.
Restlesswildman
Nov 3, 2013 04:43 PM
el01
2004 - 2008 F150
Feb 13, 2011 06:00 PM
bluegrassford
1997 - 2003 F150
Oct 22, 2010 02:44 PM
chaser1602
1997 - 2003 F150
May 25, 2007 01:10 PM
