Most useful scanner
Old Dec 4, 2023 | 07:09 PM
Lafrenger's Avatar
Lafrenger
Trailering
Most useful scanner
For my 1996 Ford F250 7.3L would be nice to also be able to check injectors and glow plugs.
Old Dec 5, 2023 | 08:10 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...2-scanner.html
is what i use
none can monitor the GPs
Old Dec 5, 2023 | 08:39 AM
Lafrenger's Avatar
Lafrenger
Trailering
is what i use
But it will tell me if I have a injector issue? Just spent to much time diagnosing a bad wire under the valve cover to my number 5 injector. Had a guy with the right scanner find it in two minutes. I want to be able to diagnose any problems. And the setup you recommend here will do that?
Old Dec 5, 2023 | 09:32 AM
knottyrope's Avatar
knottyrope
That scanner can tell if an injector is not seen by the IDM
The PCM will toss a code that it can read if injector coil/wiring is open or shorted out
can also look at IPR% duty to see if injection system is leaking internally.
Old Dec 5, 2023 | 09:39 AM
Lafrenger's Avatar
Lafrenger
Trailering
Thanks sir will get it
Old Dec 5, 2023 | 10:17 AM
Lafrenger's Avatar
Lafrenger
Trailering
Is this the right one? And an old galaxy tablet is what I need?
Amazon Amazon
Old Dec 5, 2023 | 11:43 AM
knottyrope's Avatar
knottyrope
https://www.ebay.com/itm/292316820894
is what i have
Old Dec 5, 2023 | 02:49 PM
BuckHammer's Avatar
BuckHammer
I asked about OBD2 scanners here a while ago. Lots of people chimed in here with good advice.
https://www.ford-trucks.com/forums/1...-scanners.html
Old Dec 18, 2023 | 08:42 AM
Lafrenger's Avatar
Lafrenger
Trailering
Computer illiterate
Would a older IPAd Pro 12.9" work to download the info to access the codes. Sorry I'm not much up on this stuff this is cheap and I can just use it for scanning and getting codes?
Old Dec 18, 2023 | 01:04 PM
knottyrope's Avatar
knottyrope
i dont know, i use android
Old Dec 19, 2023 | 05:07 PM
Talyn's Avatar
Talyn
https://www.riffraffdiesel.com/autoe...mestic-bundle/
queen of spades
Aug 21, 2013 02:23 AM
sammydiesel13
15
Oct 18, 2012 06:38 PM
chris64
19
May 21, 2010 10:42 AM
blueeyedfordguy
General Diesel Discussion
May 4, 2010 09:48 PM
