Door Bottom, Cab Corner Alignment
I stare at the truck from long periods of time trying the figure out how to proceed. I am thinking is that I need to start from bottom of the Cowel and trim the inner and outer door patch panels until the bottom of the outer door patch panel aligns with the bottom of the cowl. Then trim the inner and outer door patch panels so that the bottom back side of the door matches previous measurements that I took. Then I would modify the crap out the cab corner patch panel so that the bottom matches the bottom of the door and matches the curve of the outer door skin.
Anybody have experience with this challenge that you can share?
Thanks,
Jerry
I have had much difficulty with the patch panels that I have purchased! In particular I spent much time cutting and welding the driver door inner lower door patch panel to fit! Thanks, Greg Rogers, for your link. It does look like the inner patch panel fit much better than
mine did. I will change vendors to one that reports making their own patch panels when I work the passenger door and cab corner. Concerning the cab corner, I have not been able to find any reference material on working that grooved part that snugs against the inner door sill. Most of the info I have found shows work on the rest of the cab corner but not the inner door sill area. I cut the old, grooved part off and welded it to the new. I temporarily attached the cab corner at Roger's suggestion then installed the door.
To address my challenge of getting the bottom of the cowl post, door and cab corner to align I installed new door hinges. What surprised me is that the door set too deep into the frame. I had to add 1/8" shims between the hinge flange and the door to get anywhere close to flush at the door and body junction. I have the door aligned as much as feasible, but the gap is not consistent. I have found that the gap specs for 53-55 F100 is for a 5/32" gap but have not found what the 56 should be. I imagine it would also be 5/32"? Does anyone have this info?
I installed small pieces of sheet metal to simulate the outer skin at the bottom corners of the door to see how each aligned with the cowl and cab corner bottom. They are close but need some adjustment. I am not certain how much I can manipulate the flange on the inner panel bottom to move it up a bit. I can bend it inward some but am not certain how that would impact the curve of the door bottom outer skin and how that would impact its installation.
The back corner bottom aligns pretty close to the bottom of the cab corner but on the other bottom corner the door extends down further when compared to the cowl bottom. I could trim some of that flange that the outer skin folds over, but the flange isn't very wide, maybe 1/2".
So, I am looking for two things. The specified door gap for the 56 F100 and information and guidance from anyone that has worked the bottom of the door to get the cowl, door and cab corner to align.
Thank you!
Jerry
lllllllllllllll
I am not a body guy and lack the skill and talent level to do any sheet metal work like you have been doing. But I have aligned my doors on my 56, and I just wanted to confirm for you that yes you are correct, the factory service manual says the door gaps are 5/32". I found on a Chevy Tri-5 forum a handy tip that might help you get those gaps. Use slit 5/16" rubber hose to act as spacers on the doors' edges. The outside to inside wall thickness of 5/16 hose is 5/32". My gaps aren't perfect, but it sure helped make them much better!
If I were you I would forget the door skin for now and get the corner completed first. Then correct the door to match. If the opposite side is still intact you could make a template of the contour of the cab corner where it meets the door and use it as a guide.
Edit to add - the new door hinges commonly need shimmed. There is an option to buy hinges with some adjustment in them but shims will do fine. You may need longer screws though if they are thick. It can be difficult to deal with the door shutline if the latch pulls it around so I would remove that and weld a couple of temporary washers to simulate it's position when closed so they overlap the door/gap/B post
I haven't posted on this for a while but am making slow progress on the cab corner install.
While working on the cab corner I have been searching for better lower outer door patch panels. In past I had purchased an outer bottom driver door patch panel but it measured 35 1/2 inches while the existing panel is 35 5/8 inches.
I reached out to several vendors and chose one that reported that theirs measured 35 3/4 inches. I ordered and received two of these patch panels one for each side of the truck. Both were 35 1/2 inches wide. The company was kind enough to refund my money.
I am posting this because I discovered that the patch panels I received were manufactured in Taiwan and many vendors sell these. They are advertised as 35 3/4 inches wide but are all mostly 35 1/2 inches wide. I heard that the U.S. manufactured patch panels were of better quality and would most likely fit so started searching for a pair. Unless someone knows of a source for these outer lower door patch panels, I believe that they are no longer produced within the U.S.
If you know of a source for a U.S. made outer bottom door patch panel please let me know where to find them.
Otherwise, I am left with the patch panels that need to be widened 1/8 inches. I could cut them vertically along the edge and add material and, but this scares me as the panel covers a large area and I fear I would cause distortion. Another options is to install the patch panel then add material to the edge. I am not certain how easy this might be. A final option is to make my own patch panel, but I do not have the skills or equipment to get the vertical and horizontal curve needed to fit the door.
If have modified and used these shorter patch panel, can you share your experience and pictures with me?
Concerning the inner lower door patch panel as you can see in earlier pics, I've installed one on the driver door. I had to cut and cut and bend and reweld much of it to get it to fit. The reliefs stamped into the panel were much shallower than stock and the side was not as thick as the thickness of the door, so I had to add material. I have a second inner patch panel for the passenger door but it looks exactly like the driver door patch panel that I installed. Both were made in Taiwan. I have found a U.S. made inner bottom door patch panel and I'm thinking of purchasing it in hopes that it fits better thus requiring less modifications. Anyone work with U.S. made inner bottom door patch panels that can provide their review?
Thanks all,
Jerry
For the door bottom panel - the panel is short by a distance no question. Just concentrate on the shape of the section itself (which is already bad enough). As long as it reaches the edge that's fine. You can then weld a return to it by welding along the edge before grinding it back smooth. There are quite a few YouTube videos with that technique. I'll dig one out and post it here.
I started at the door and went around the back of the cab. I have to say however, that no decent person would have stayed within hearing range of what was coming out of my mouth well working with this thing; Once I got it in place I discovered that the sheetmetal indentation didn't line up with the patch panel no matter how I tried to fit it. It was about a 1/4 inch off and I finally cut that amount out of the panel and welded it back together, as shone in the second photo.
Cut to match
As for the rears, they weren't as bad, but they also are stamped a tiny bit bigger, and with thicker steel than the stock metal. They both required quite a bit of massaging around the jambs.
