EXT to Single Cab Conversion
Old Dec 4, 2023 | 07:53 AM
Soundwave887's Avatar
Soundwave887
4wd Low
My truck has an EXT Cab/Long Bed and I want to turn it into a Single Cab/Custom Flat Bed. I want to keep my original cab and cut the excess off and weld it, would cab bracing be necessary? Is there any information that I should know? Thank you (I know buying a new truck would be easier)
Old Dec 4, 2023 | 10:30 AM
OBS460's Avatar
OBS460
Please don't frankentruck another OBS. Sell yours and find a regular cab. There might even be one with a flatbed already.
Old Dec 4, 2023 | 11:11 AM
Soundwave887
4wd Low
this is my world and you merely live in it
Old Dec 4, 2023 | 11:17 AM
OBS460's Avatar
OBS460
The fact that you are asking for advice about a job like this is evidence enough of the hack job that'll be on marketplace before long.
You know what, hack away. This can only increase the value of my spotless regular cab.
Old Dec 4, 2023 | 11:20 AM
Soundwave887
4wd Low
fool, you are unaware of the abilities I’ve harnessed. I’m unstoppable, your response is evidence enough that you don’t have the ***** to complete a job to this degree. Checkmate B)
Old Dec 4, 2023 | 11:24 AM
OBS460's Avatar
OBS460
I have the intelligence to just purchase the right truck in good condition so I dont have to cut and hack anything. Good luck with frankentruck. Dont forget to post pictures of your journey.
Old Dec 4, 2023 | 11:43 AM
Soundwave887
4wd Low
wealth won’t bring you the glory that I will possess, check your inbox in a couple years
Old Dec 4, 2023 | 11:55 AM
JKBrad's Avatar
JKBrad
Then why'd you ask? The tome and work to make a Super Cab a regular cab is not worth the effort. Even then, you would need to buy a regular cab to section the back off. Why not just use the entire donor cab?
Return to the world you live in and use your superpowers. Then come back and triumphantly post pictures of your custom coachwork.
The easiest and most cost effective way to do it would be to buy a regular cab flatbed truck. The easiest way with the best outcome for the truck you already have is to find an 80-97 cab and use the front sheetmetal, doors and most of the interior from your truck. If you find a 92+ cab, with a good interior that would be even better.
Do you plan to have a 9.5-10' flatbed? Or do you want to hack the frame for an 8' bed?
Old Dec 4, 2023 | 12:47 PM
jwitty's Avatar
jwitty
Wtf is going on with this thread. Is the matrix faulty at the moment?
Old Dec 4, 2023 | 01:22 PM
OBSession05's Avatar
OBSession05
That's a good ****ing question. I say let the guy do what he wants. No reason to fire shots back at something he wants to do. I think just getting a regular cab would be easier and if you want a super long flatbed go for it. If you just want an 8 foot flatbed and regular cab just get another truck and that'll be saving you money in the end. Half these trucks have already been hacked. They have become anything from bone stock to a full on off-road beast. Kind of too late to save these things now. They're either rusting away or wrecked or brand new, you name it, it's probably been done. That's my 2 cents. Good luck to ya!
Old Dec 4, 2023 | 01:25 PM
Scndsin's Avatar
Scndsin
Originally Posted by jwitty
... Is the matrix faulty at the moment?
Deja' vooo all over again I tell ya'.
Seenit before...
Old Dec 4, 2023 | 03:13 PM
Soup bean's Avatar
Soup bean
If you're going to attempt this, you want to have some kind of jig in place to hold the original shape of the cab.
I don't know exactly what that would entail but it would be in the ball park of a rotisserie like is used on body off restorations.
Think in terms of the walls of a house. The interior sheet rock and exterior plywood are structural, so the framing keeps its shape.
Sheet metal flex is an issue. it's beyond my skills.
Old Dec 4, 2023 | 04:48 PM
Soundwave887
4wd Low
Thank you sir, I agree. These trucks are a dime a dozen, You can find these trucks easy in Florida and cheap. I really just have an attachment to this truck so I’m gonna be buried with it.
Old Dec 4, 2023 | 05:03 PM
Soundwave887
4wd Low
Right, like the cab bracing I mentioned. I saw that when you cut out the cab floor, you can get away with bracing the doors in a cross pattern. I’d imagine if I were to cut the back half of the cab off, I would brace the corners of the main cab and right before the cut straight up and down (to keep the roof from dimpling) I’d also brace the rear half of the cab, so when I remove the “middle section” (where the EXT Cab glass is) I could theoretically just “scooch” the end piece up to the main part of the cab and weld it up.
a lot of measuring and photoshop/drawing will be a must to get it right, but it’s possible in my brain.
Old Dec 4, 2023 | 07:12 PM
OBSession05
If you successfully accomplish this please post pics or make a thread about it. Kind of interested to see where this goes.
