getting the bed off
Old Nov 22, 2003 | 07:05 PM
elsmith's Avatar
elsmith
getting the bed off
I am trying to get the bed off of a 72 f250. I cant get some of the bolts out. The top of the bolt just turns and I cant get vice grips on them. How else can I get them out? Can I take a grinder and cut the top off? I don't think the bolts would slide through the bottom if I did that though. Thanks For any advice. Eric
Old Nov 22, 2003 | 09:15 PM
460 Crew's Avatar
460 Crew
Either put a tach weld on the head and bed till you free the nut off and grind the weld off when done or torch the nuts off from underneath. Also try using some PB blaster penetrating spray stuff works wonders.
Old Nov 22, 2003 | 10:17 PM
willowbilly3's Avatar
willowbilly3
I always jut torched them off from below.
Old Nov 23, 2003 | 02:11 PM
elsmith's Avatar
elsmith
Unfortunatly I don't have a torch. I wish I did. I just may have to invest in one sometime. I sprayed them with liquid wrench last night. I might use vice grips on the threads until I can cut the bolt on the bottom above the nut. Thanks Eric
Old Nov 23, 2003 | 02:36 PM
trouble's Avatar
trouble
Grind the head of the bolt off fluchs and the take a punch and knock them out .. Done it many times, it will work .
Old Nov 23, 2003 | 05:38 PM
willowbilly3
also el you may consider investing in a nutcracker. They aren't that expensive and do work on things like that.
Old Nov 23, 2003 | 09:30 PM
rebocardo's Avatar
rebocardo
If you are talking carriage bolts, lift them up with a screw driver and jam the screw driver into the hole and pound the bolt down on top of the screw driver.
If that does not work, use a pry bar or jack to push the bed up against the carriage bolt while you take the nut off with an impact gun.
Sometimes what I do with carriage bolts is lift them up enough with a screw driver to slip a sawzall metal blade in there and cut the head off.
Old Nov 23, 2003 | 09:37 PM
MudinMan19704x4's Avatar
MudinMan19704x4
grinder...torch....boltcutters.......need i go on.........
Old Nov 23, 2003 | 10:17 PM
tediesel's Avatar
tediesel
On the last 2 I did I used a gas cut off saw and x'd the top of the bed bolts. Then chisled the last little bits off before I cut into the bed. Probobly took 15 minutes to do them all and I didn't even bleed!
