GasMileage
Old Apr 11, 2002 | 02:59 PM
BigJohn64's Avatar
BigJohn64
Post GasMileage
I was wondering if anybody has had luck improving the gas mileage on a 2000 Ex 5.4L 4x4 w 4.10 gears.Its about 10.5-11mpg now.Thanx in advance John
Old Apr 11, 2002 | 03:32 PM
Monsta's Avatar
Monsta
Sit. Stay.
GasMileage
Hey John,
Welcome to FTE. You're one of the few that I've talked with that owns a 5.4L equipped Excursion.
The only thing that I can think of off the top of my head would be to change the gear sets to 3.73's. But then I'm afraid you'd have a bit of a dog on yer hands...
The simple things though...
Keep your tires above the "recommended" tire pressure. I run 60psi all the way around but then I have put E-range tires on it and they can hold 80psi. Just bumping yours up will make a small difference.
I'm a firm believer in synthetics. Mobil 1 in the engine and transmission could give some increases (albiet small but anything helps)
Reduce weight. Make sure you keep as much unnecessary weight out of the truck as you can.
Over on the Super Duty forum, guys have posted their results from various aftermarket add-on and whatnot for the 5.4L. Do a search and see what they are doing to help improve their mileage.
Your driving style affects your mileage more than anything else but I'm sure you already knew that...
Old Apr 12, 2002 | 05:01 PM
BigJohn64's Avatar
BigJohn64
GasMileage
Thanx for all the info Monsta.If I try some of add-ons I'll post my results.I really got a good deal on this Ex 45000 miles and I paid 19500 or at least I think I did.
Old May 24, 2002 | 03:46 PM
BigJohn64's Avatar
BigJohn64
GasMileage
I started with a K&N filter,tornado-air and increased tire psi to 5# just below tire specs,mpg around town 11.5 and on the road 13,so it made a little improvement.I thinking about a chip or programmer next.Will post results of that.Total cost of improvement $132.00
Old May 24, 2002 | 06:45 PM
Monsta's Avatar
Monsta
Sit. Stay.
GasMileage
I bet the only thing that really made any difference was the increase in tire pressure.
Old May 25, 2002 | 12:26 AM
LByellowStang's Avatar
LByellowStang
GasMileage
Fireboater
6.2L V8
Apr 16, 2013 12:49 PM
4tl8ford
24
Aug 2, 2011 07:01 AM
jcb67
Appearance & Dress-Up
Aug 24, 2003 12:19 AM
Johns45
1947 and Older Ford Trucks
Mar 24, 2003 09:46 PM
