TBI setup
Old Nov 22, 2003 | 01:59 PM
dbarracuda's Avatar
dbarracuda
TBI setup
Hey guys I was just wondering if anyone has ever adapted a TBI fuel injection setup to fit a 400. If so what kinda power and gas milage did it get? I was thinking of just getting one out of a juk yard not the aftermarket kind.
THanks
David
Old Nov 23, 2003 | 12:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
You would need a way to program the OEM unit. That may be very difficult or $$$.
Old Nov 23, 2003 | 03:55 AM
scroob's Avatar
scroob
What was the last year that 400s were made? 1982? I had a 1983 Crown Vic wagon with a 302 that had the TBI system. Very possible that setup was available in 1982 as well, but I don't know if it was ever on a 400.
It seems that the programming would be the same for any engine. Fuel/air ratio is the same. Sensors supply input. O2 sensor, throttle position sensor, and engine speed sensor were the only ones my '83 had. No MAF sensor.
The biggest problem I would see is that a TBI requires a high pressure tank mounted fuel pump, and a return line.
Also, the ignition system is involved. My '83 had the gutless distributor and EEC-III. I suppose you could run a regular ignition system, but you'd lose a lot of the advantage of running a computer controlled fuel injection system, since the computer couldn't vary the ignition timing in concert with the air/fuel mix.
As with anything else, it coud be done, but would it be worth it? Doubtful. The TBI systems were a step up from a carb, but not a large one.
Old Nov 23, 2003 | 03:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Programming varies with engine, cam, injectors, gear ratio, etc etc etc. Not quite the same thing on all engines.
Aftermarket unit is the only way to go here. Try a Holley unit.
Old Nov 23, 2003 | 08:13 PM
Ecuri's Avatar
Ecuri
http://www.customefis.com/index.html
I have no idea if this is the way to go or not. But it is food for thought. GL
Old Nov 23, 2003 | 08:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
That site has a ton of info, even a special section on why reprogramming is required. -Thanks
Old Nov 26, 2003 | 10:51 AM
Ecuri's Avatar
Ecuri
I like the TPI even better. Again, as our thread-starter requested: Can we get some testimonials!?!?! I can't believe no one has injected a 400.
Old Nov 29, 2003 | 02:32 AM
willd's Avatar
willd
Howell makes tbi units to fit just about anything.
They have complete kits, or you can mix-n-match yours.
Old Nov 29, 2003 | 07:03 PM
dickboyd69's Avatar
dickboyd69
Well I know at least one person with a injected 400......Me. I got a 77 f150 w/ a 400 in it. About 4 months ago my carb was getting to the point of needing to be rebuilt. Instead of spending money on something i didn't care for in the first place I decided to upgrade it. I had been looking at fuel injection for a while and decided to spend the extra money i had at the time. I ordered Holleys 700 cfm commander 950 system. To take full avantage of computer controlled stuff I got a dizzy out of a 90's 460 and slid that it. Got it all on and tuned and well i like it. mpg went from 7-8 in town to 11-12. Still not the best but not bad for a worn out motor that needs LOTS of performance mods and being driving by a idiot teenager. Worth $1300? That all depends on the person. It'll still take a while to pay for itself in fuel bills but the driveabilty and reliablity are finally getting closer to where I like em. So I like it.
