I've had a little smoke out of one my exhaust pipes for a while now. It's been losing water, and I'm pretty sure that's where it's going. Got back from a drive earlier and I think it's starting to get worse. Is it possibly the head gasket, or am I likely looking at a crack somewhere? Should I pull the head and see what I can find?
Head gasket would be the first suspect, unless there's some reason to believe you had an incident that would cause a crack, freezing or overheating, etc. You can always try one of the stop leak remedies if you want to give that a shot first.
It's good to hear from you. We met during the Truckstock at Butler State Park. Ross taught me a trick that helped a lot. Take a couple of long 7/16 inch bolts, grind off the heads, and cut yourself a slot for a big flat head screwdriver in place of the head. They make great placeholders for the head when you slide it on and off the engine block when you get started on that project.
Before you pull a head, get a cooling system pressure tester (loaner tool set from AutoZone or O'Reilly's) and pump the system up to 4 psi (NOT any higher). If it won't hold pressure, you've got a leak somewhere.
Is there any sign of water/coolant in the oil? When running, are there any bubbles in the radiator?
There's no coolant in the oil. I'll check the radiator for bubbles.
"...pump the system up to 4 psi (NOT any higher)..."
Story time. A few years back I was having my radiator re-cored and the shop was taking forever. I got impatient and bought a relatively cheap aluminum radiator which I used for a few months. I didn't know any better, so I didn't check what the pressure was on the cap. It wasn't until after I put my old radiator back in that I learned about the cap pressure ratings. If I recall correctly, I checked and the aluminum rad cap was rated at 12lbs. I remember thinking, "Oh, that's why the heater core suddenly sprung a leak."
