2005 axle dust shield
Old Nov 17, 2023 | 12:13 AM
mrwrench's Avatar
mrwrench
is the new axle dust shield metallic the one that replaced the ruber seal that goes on the axle shaft ? today I remove the axle shaft and there is not seal in the axle tube , only the broken rubber one on the shat nest to the ujoint....is that right? thanks
Old Nov 18, 2023 | 09:59 AM
Fuzzpuss's Avatar
Fuzzpuss
It's metal with rubber in the middle where the axle shaft goes through. I bought some for my 03 because rockauto said they would work but they're only for the coil spring axle assembly. Big improvement over the rubber donut, which like the stock 6.0 transmission filter, is only good for keeping out rocks.
t.taylor6257
Jun 4, 2020 06:50 AM
Jason Trimberger
Aug 29, 2012 05:35 PM
hotrod351
Mar 30, 2012 08:08 AM
Dru71
Oct 11, 2005 01:18 AM
fatdaddy
May 12, 2002 10:03 PM
