Help I have a 1971 ford F250 I wanted to switch to disk brakes I found donor 1975 f250 removed I beams and spindles removed old drum brake setup on weekend tried to install new ones tie rod on drum brakes comes up through taper from the bottom but 1975 spindles tie rod goes in from the top because of the taper but since the hole in the trailing arms limits tie rod going high enough can I buy 1975 steering linkages and install will they fit the pitman arm ect or if I get 75 pitman arm will it fit the box I have installed power steering box on it of a 1970 f250?
Yes, you will need all the drag links from a 75-79 model.
