Modular V10 (6.8l)
01 6.8 v10
Old Nov 10, 2023 | 07:02 PM
newfordman2022's Avatar
newfordman2022
2nd Gear
01 6.8 v10
Hey guys so I just bought this truck and it has no codes but idles slightly rough when in park and reverse but when in gear it get worse and had a hesitation to take off at low rpm’s, I also noticed that the short bank fuel trim was running from a negative 2-12 and bank 2 was a positive 2-12 not sure what could cause this but I’m stumped as to where to start diagnosing!
Old Nov 10, 2023 | 07:47 PM
85e150's Avatar
85e150
Welcome to FTE. I moved you to the correct forum for the V10.
What model is your '01?
What kind of code reader did you try to read codes with?
Where are you getting your fuel trim info?
Old Nov 11, 2023 | 12:06 PM
newfordman2022
2nd Gear
It is a f250sd with an automatic trans truck has over 300k and no blow by when oil cap is flipped over on the spout. I used an acucheck or something like that it was my buddy’s I borrowed for the day. As for the fuel trim info I used the live data selection on the code reader to pull data I posted about. Thank you for moving the post to the correct area as I’m new to using forums.
Bak20041
Modular V10 (6.8l)
Jul 15, 2022 02:43 PM
Akranz1507
Jul 11, 2022 01:54 PM
Bak20041
Modular V10 (6.8l)
Mar 11, 2022 08:01 PM
damone
15
Jun 5, 2006 11:27 AM
