intake 351M
Old Nov 8, 2023 | 12:49 PM
judie bootie's Avatar
judie bootie
4wd Low
intake 351M
3rd time just puttin on a new aluminum manifold. Should I even put end seals on they always leak. So what the hell should I do?
Old Nov 8, 2023 | 01:00 PM
ranger140892's Avatar
ranger140892
Grumpy goat
I used the valley pan, with thin bead of RTV around all ports. Then more RTV on the walls. I never use the end seals.
Old Nov 9, 2023 | 03:42 PM
Pickupmanx2's Avatar
Pickupmanx2
What I did when installing my new alum intake, because the first time I did it, I had a broken back, L1 & L2 compression fracture from being stupid on my FZ09, I set it on the block and flinched/winced in pain, therefor making the manifold drop before I had it aligned, slid the rtv on the china wall and produced a leak. So to remedy that, I took 4 of the old intake bolts, cut the heads off, ground them smooth with a bit of taper and put them in the holes finger tight. Then, after I had cleaned all the smeared rtv off and was re-installing manifold, I was able to set it straight down on the 4 guide pins and drop it exactly in place. Wish I would've taken a pic, but I think you can get the right idea... the four center of the manifold bolts that stick straight up.
Old Nov 10, 2023 | 10:16 AM
440 sixpack's Avatar
440 sixpack
Use TRS for the end seals and be done with it. silicone or TRS around the water ports and Hylomar or Permatex #1 or #2 on the ports. gas eats silicone so it can't be used .
f250custom78
Nov 21, 2012 02:57 AM
IowaTower
Jan 29, 2006 02:30 PM
Ford150/428/dud
May 14, 2005 09:26 AM
qikbbstang
Jun 18, 2001 07:43 AM
