HPOP replacement
Old Nov 6, 2023 | 11:24 PM
luvemhot's Avatar
luvemhot
HPOP replacement
After 400k miles it appears that my HPOP is at the end of its useful life. I am looking at the adrenaline from thoroughbred diesel. I plan to upgrade my injectors when it is time. Looking for advice on what HPOP to buy.
Thanks for the insight
Keith
Old Nov 6, 2023 | 11:30 PM
Truckwardo's Avatar
Truckwardo
If you're doing injectors you might want to nail down the exact ones you plan to use. To make sure they work together.
Old Nov 6, 2023 | 11:37 PM
luvemhot's Avatar
luvemhot
ok thanks Keith
Old Nov 7, 2023 | 03:20 AM
INFRNL's Avatar
INFRNL
either adrenaline or if you want to save a little the CNC Fab HPOP is a great choice as well.
If you can hold out a bit longer I believe dieselsite usually has a black friday sale on them. At least he used to. It used to be like $100 off
Old Nov 7, 2023 | 05:46 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
We have had great success with the T500.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Nov 7, 2023 | 08:54 AM
luvemhot's Avatar
luvemhot
I wil do that always like saving 100$
Thanks Keith
Old Nov 7, 2023 | 12:43 PM
INFRNL's Avatar
INFRNL
which one you going for? CNC is probably $100 savings (haven't looked at current prices)
T500 that DP rec'd used to be very affordable option. I din't know they were still being built. That goes to say they are a reliable pump as well.
Going off your response i'm guessing you are stuck on the Adrenaline.
Old Nov 7, 2023 | 08:37 PM
luvemhot's Avatar
luvemhot
infrnl not stuck on the Adrenaline it was the only one I knew of other than stock one from auto zone or the dealer.
I sent question to t500
Old Nov 7, 2023 | 08:42 PM
RacinJasonWV's Avatar
RacinJasonWV
Send a question to CNC Fab as well. I’ve heard good things about their pumps.
Old Nov 7, 2023 | 09:28 PM
Tpayne621's Avatar
Tpayne621
He's also doing a t800 now which flows more. I would assume like a cnc stage 2.
Old Nov 7, 2023 | 09:47 PM
INFRNL's Avatar
INFRNL
i have a stage 2 but haven't needed it yet, so i can't say.
Nice. I guess i've been out of it for too long. Glad he is still doing stuff.
I went with CNC because he looked at my Stealth SRP after it had an early failure. But actually I went adrenaline first which is still on my current truck. I had a second adrenaline but my crybaby friend was in desperate need. Price went up too much, so i chose to try a CNC instead. something like that.
CNC is still on the shelf waiting for my lazy butt to build my project truck
Old Nov 8, 2023 | 07:07 AM
Tpayne621's Avatar
Tpayne621
I've had cnc stage 2 in mine now for around a year. No complaints.
Old Nov 8, 2023 | 07:20 AM
Dan V's Avatar
Dan V
I recently installed a CNC Fab Stage 2 HPOP....no issues so far.
Old Nov 9, 2023 | 04:59 PM
INFRNL's Avatar
INFRNL
Yeah, I didn't have issues with my Stealth either for several years until it failed out of the blue with no warning signs...and unfortunately they shut down or whatever.
I can't remember what year I replaced it with the adrenaline. maybe 16/17 but no later than 2018. I'd have to do some digging to find out.
I'd imagine/hope the CNC is just as reliable as the T500 and Adrenaline
Stock pumps that came with the truck were definitely reliable but an upgrade is obviously necessary when upgrading injectors.
Old Nov 9, 2023 | 07:18 PM
luvemhot's Avatar
luvemhot
thanks for every ones help I am thinking I am going to go with the T-500. And replacing my injectors with FFD remained 160cc with the 30% over stock nozzle. Does that sound like a good match? I am not want a hot rod. Just want to pull my trailer in the mountains and not have my pyros burn up the engine.
