Is my VRV dead?
Coming home I drove on the highway. It seemed to do ok, but getting off the highway and driving through town the 1-2 shift was at 18mph followed immediately by the 2-3 shift.
I tested the vacuum going into the VRV (top port) with the truck idling. It has 20" of Hg. Then I followed the directions here in an attempt to adjust it.
https://www.nickpisca.com/diesel/fue...d-calibration/
No matter what throttle position or VRV position I get 0" of Hg from the bottom VRV port (going to the vacuum modulator on the transmission).
https://www.ford-trucks.com/forums/1...g-failure.html
When I was driving home yesterday I started in 2, then manually shifted to 1 and then D. It drove fine that way. Apparently that B&M shift kit allows manual operation of the transmission. This is puzzling, some sellers indicate that you can't control the transmission manually.
https://www.summitracing.com/parts/bmm-40228
However, other parts warehouses mention that you can manually control the transmission.
https://www.holley.com/products/driv...ts/parts/40228
I looked in my parts bin and found the original instructions. The kit I got was closer to what was pictured in the Summit link. I didn't get a valve body separator plate.
Ultimately, I think I'm going to drive my truck again today and try to shift the transmission manually (2,1,D). I'll provide an update. My daily driver 20 F150 is actually in the shop getting a 10R80 rebuild at 55k miles.
I guess I need to inquire about a new (or rebuilt) VRV from the above supplier. I had a lead on a parts truck and when I mentioned it to Momma she shot that down pretty quick.
From page 80 of the 1986 F-Series 150-350 owner's guide:
The automatic transmission provides fully automatic operation in D(DRIVE). For manual control start in 1 (LOW) or 2 (SECOND) and then shift manually.
Apparently, no shift kit is needed to operate the C6 manually.
