So got these spot on the cluster lens, appears to be on the inside tried cleaning it. Question is if I remove the cluster can I pop the lens off and clean the inside of the len? Know folks have changed cluster so someone must know.
They may not be on the inside. Some cleaners will discolor the clear plastic. I did that on my civic a decade ago and learned to never use any cleaners on the gauge cluster clear plastic.
Yes, the lens comes off so you can clean the inside. I'll bet that's on the outside though. If it doesn't wipe off you can use plastic polish to repair the surface.
