This forum has been very helpful in the past, thank you.
I just got new tires a couple weeks ago. I now have a low pressure indicator light on dash after a couple weeks. I checked, all the tires have the correct amount of pressure.
At Les Schwab, they said sometimes in cold weather you can get an indication of tire low pressure. (not sure about that, temp here has only been onthe low 30's.)
A couple of years ago, I had a bad tire pressure sensor. I saw somewhere to reset the indicator light, you have to let all the air out of the tires and refil them to get it to reset.
