Sponsored by: Real Truck
Alignment
Old Nov 21, 2003 | 08:52 PM
HerbertKornfeld's Avatar
HerbertKornfeld
Alignment
Where do y'all get your Superduty's aligned? How much do yuo pay?
I'm having trouble finding a place - everywhere I call says that the truck won't fit on the rack.
I'm having some strange wear on the rear tire - heavy wear on the inside. Anyone else ever had this problem?
Old Nov 21, 2003 | 09:33 PM
99f350sd's Avatar
99f350sd
Rear there's no alignment on the rear just the front. You might have broke a belt on a tire..Worst case the spring locator is broke or something bent..
Old Nov 22, 2003 | 05:18 PM
HerbertKornfeld
Thanks 99-
I took it in and they said that, almost certainly, the back tires used to be on the front, therefore, the problem was in the front end and would be cured by an alignment.
