Overheating question
Old Oct 31, 2023 | 08:57 PM
Coy47's Avatar
Coy47
1st Gear
I have a 1971 302 with a C4 automatic. The engine has less than 15000 miles on it. The radiator is new. It’s a triple core aluminum oversized with a shroud. If I put it in gear and let it sit with the brake applied it overheats, or reaches 220 degrees plus in about 15/20 minutes. I’m basically talking about a drive-thru scenario. Is that normal or acceptable? Any thoughts? Any help is greatly appreciated.
Old Oct 31, 2023 | 09:17 PM
jzjames's Avatar
jzjames
I believe that sounds normal..
Old Nov 1, 2023 | 09:19 AM
nutter3's Avatar
nutter3
Anytime sitting in traffic etc for any length of time, I slip my automatic transmissions into neutral. I learned this from watching the temp gauge on the 47RE behind my Cummins in a dodge. Heat will go up extremely fast in stop and go traffic.
Old Nov 1, 2023 | 12:48 PM
GPatrick's Avatar
GPatrick
Your idle mixture and timing also play a big part in how hot it will get sitting at idle. Low base timing and using the ported rather than full manifold vacuum port will keep timing retarded and this can lead to overheating. You might try more base timing and compare and tune the idle screws to best idle vacuum plus 1/8 turn. An external transmission cooler will take some of the load off the radiator as well.
Suitsnosocks
Jun 5, 2022 07:09 AM
Bootlegger's Deluxe
19
Feb 10, 2016 07:30 AM
Cerpindicular
Dec 30, 2010 02:29 PM
Guido01
1978 - 1996 Big Bronco
Nov 16, 2001 10:27 AM
charlez
Feb 24, 2001 09:10 AM
