Glow Plug Relay?
Old May 5, 2008 | 12:07 AM
blue lightnin's Avatar
blue lightnin
thanx dustan for the excellant pic on the relay that looks like voltage regulater i saw them on my truck i will check it out....
Old May 5, 2008 | 12:09 AM
blue lightnin
ps to smokin what was the test to find if gpr is bad?
Old May 5, 2008 | 08:49 AM
Smokin''s Avatar
Smokin'
Smokin
Hey blue lightnin, I just sent you an email, don't forget to open up the attachment.
Old May 5, 2008 | 01:17 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Return of the Living Dead...thread
Here's a pic of the 2 relays (the right side of the pic is the front of the truck for orientation)
Of the two brown relays, the on one the left is the GPR. The other is the AIH relay.
Old May 6, 2008 | 12:37 AM
dustan52's Avatar
dustan52
no problem
Old Jan 23, 2014 | 11:56 AM
deck60's Avatar
deck60
what does gpr stand for
and what does aih stand for
I just got a 2000 f250 with the 7.3 went to start it and the block heater is not warm I have a magnetic heater on it now but when I cycle key I don't hear a relay click
Old Jan 23, 2014 | 11:59 AM
white Buffalo's Avatar
white Buffalo
GPR = Glow Plug Relay
AIH = Air Intake Heater
Old Jan 23, 2014 | 12:05 PM
deck60's Avatar
deck60
thanks now to check with an volt-ohm meter
Old Jan 23, 2014 | 12:30 PM
deck60's Avatar
deck60
this truck has only 1 relay I am assuming it is a glow plug relay and I am not getting any power coming out of it
my truck has this on it http://www.ebay.com/itm/Diesel-Glow-Plug-Relay-FORD-TURBO-DIESEL-6-0L-7-3L-FORD-F250-FORD-F350-F450-F550-/310831736986?pt=Motors_Car_Truck_Parts_Accessories&hash=item485f03e89a&vxp=mtr
can this be bypassed and a normal relay installed
Old Jan 23, 2014 | 01:39 PM
white Buffalo
Your truck (like many others and all Excursions) has the California emissions package. The One relay you refer to is the AIH relay and the other bigger one (the one in the link), is a Glow Plug Control Module. I'll post a pick & a link that explains it better. What are you trying to test ? Glow plugs?
Old Jan 23, 2014 | 02:04 PM
white Buffalo
Does yours look like this:
or does it have 2 relays like this:
Old Jan 23, 2014 | 02:09 PM
white Buffalo
Here is a link to Woodnthings' website that explains the glow plug system on both setups...
https://sites.google.com/site/woodnt...ow-plug-system
and here is a link to testing the models with the Glow Plug Control Module:
https://docs.google.com/viewer?a=v&p...ZTZiYTE4NzdlOA
Old Jan 23, 2014 | 02:18 PM
  #28
Haggs21's Avatar
Haggs21
AIH- Air Intake Heater. Not all versions have it. My Early 99 don't. A lot of people delete it.
-Glow Plug Relay-
Buy 2 if aftermarket and keep in toolbox,you'll change more than your underwear. I went stancore from allied last month and lovin it thus far.
If never did GP-Glow Plugs they or Under Valve cover wire harness goes bad. (a harness inside VC that powers each GP. Also check for corrosion on the plug on the top of each VC. Carfully unplug and look at connectors.
After GP work correctly if you still have issues with cold starts try 5w-40 CJ4 rated oil. 15w is thick @ 70* let alone 10*. Helped mine but I now know my hpop is weak.
Old Oct 31, 2014 | 09:38 AM
  #29
mtbnski's Avatar
mtbnski
Sorry to bring up the past, but is this the correct way to mount and wire the cheapo GPR with the incorrect mounting plate? I just bought one from Amazon and not sure if I put the leads on the right terminals.
Thanks!
Old Oct 31, 2014 | 10:01 AM
  #30
timmyboy76's Avatar
timmyboy76
yup, just installed my gpr109 the other day
