351 efi
Old 10-30-2023, 04:38 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
Knock sensor
The 302s sensor was on top rear of the block. So drilling and tapping the intake manifold near center might work. Are you experiencing pinging/spark knock?
Old 10-30-2023, 05:00 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
Well, I did... at least once.
If I'm not completely off base, the knock sensor on a 5.0 is the same pitch/size as whatever NPT as the oil pressure gauge, right?
It's not a bolt thread size... right?
Old 10-30-2023, 05:38 PM
kenny nunez
Knock sensor
I checked with a 1/2” 13 die nut and a 1/2” 13 common nut. The drain plug thread is close but it will not seal and you will not be able to get it tight enough. It would not be hard to make an adapter if you have a lathe.
Old 10-30-2023, 07:33 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Originally Posted by torq'ta 5 8
yeap, your rite!
A relative of mine has one, F-150 5.8L, 2wd SB Auto. It has less than 30K miles on it and he purchased it brand new, right here in town.
Phaeton16
16
01-25-2011 11:11 PM
Shanemh
11-18-2006 01:02 AM
alex crease
10-13-2004 05:51 AM
Nicholas
1978 - 1996 Big Bronco
06-25-2004 04:24 PM
mantta
01-20-2003 04:12 PM
Quick Reply: 351 efi
