Water Temp?
Old Nov 21, 2003 | 07:28 PM
trakman's Avatar
trakman
Water Temp?
Is it normal for a PSD to be slow about the engine temperature comming up to normal? It was about 30 degrees here at 4AM when I went to work. Under these conditions, it takes about 2 1/2 miles before it starts to warm up for heat in the cab. My V-10 only takes about 1 mile and it is nice and toasty in the cab. Wonder if a thermostate is in need of a change? Thanks
Old Nov 21, 2003 | 07:36 PM
F0rdF0rever's Avatar
F0rdF0rever
It takes my 95 almost 2 miles toget warm enough to heat the cab.
Old Nov 21, 2003 | 10:30 PM
bender97f250's Avatar
bender97f250
My 97 takes about 3 miles. I had Ford check everything out and they said this was normal and found nothing. If the truck is plugged in, it helps a bit.
Old Nov 22, 2003 | 06:27 AM
trakman's Avatar
trakman
Thanks guys...sounds like I'm right in the ball park although I'd also like to hear from someone that has a truck that is the age of mine, just to compare. Thanks again
Old Nov 24, 2003 | 07:31 PM
Thumper4995's Avatar
Thumper4995
My '99 takes about the same distance.
Old Nov 25, 2003 | 11:59 AM
HoseDog's Avatar
HoseDog
It's 2 1/2 miles of 35 MPH road to town and the freeway, and my temp guage barely moves. It doesn't take long at 65 - 70 mph to warm it up. If I head the other way, it's 7 mi. to CDA (more 35-45mph), and it still just barely starts getting warm. All this without plugging in the block heater. It's just not working hard enough at low speeds, and, of course, running the heater uses up that hot water, too.
