Hot regulator
Old Oct 27, 2023 | 09:14 AM
Will Burns's Avatar
Will Burns
1st Gear
Hot regulator
79 f150 is draining the battery. The regulator is getting hot enough that you don't care to touch it long. I have changed regulators and still have the same problem. This is happening when the key is off. If the regulator is unplugged it stops draining.
Old Oct 27, 2023 | 04:17 PM
Rubiranch's Avatar
Rubiranch
Possibly a shorted diode in the alternator.
Old Oct 27, 2023 | 04:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 take the alternator off and get it bench tested at the auto parts shop. Be ready to purchase another one. Or you have a elec wiring issue with your the circuits that stay hot with the key off. Dome light, brake lights, 4 way flashers, cig lighter, glove box light. Ignition switch to starter wiring via the battery.
Have you recently added a stereo/amp or a trailer connector?
ibew
New Member Introductions
Jan 25, 2016 11:56 AM
acerockola77
Aug 26, 2004 11:25 PM
TallPaul
Nov 15, 2001 11:59 AM
