“87 inline 6 manual swap
Old Oct 23, 2023 | 03:28 PM
Tht87f150's Avatar
Tht87f150
4wd Low
I have an 87 f150 that i want to manual swap. The truck only goes 60-65mph hoping i can get a little more top speed with manual swapping it.. what would be the best manual transmission that would fit flush onto the 300ci efi inline 6 thats relatively cheap.
and what all will i have to convert on the truck to do so..
Old Oct 23, 2023 | 03:41 PM
yardbird's Avatar
yardbird
The easiest and cheapest thing would be to change axle ratio. What ratio do you have now, 4.11? The sticker on the drivers door jam will give an axle code. If you can't decode it, post a picture of the sticker and someone will tell you exactly what you have.
Old Oct 23, 2023 | 05:12 PM
Tht87f150's Avatar
Tht87f150
4wd Low
i wanna say 3.08… it is 4x4
Old Oct 23, 2023 | 06:43 PM
jwitty's Avatar
jwitty
No way it's a 3.08. My old 66 f100 with a 3 speed and 3.25 rear and slightly oversized rear tires would run 70 at around 2500rpm. You have a have a 4.11 or something around there if you can't go faster than 65.
Old Oct 23, 2023 | 07:01 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What auto transmission and differential gear ratio is in the truck? My ‘87 Bronco (302/ C6/ 3.55) would be able to keep up with 70mph traffic.
You could put an AOD in it to keep it an auto or would have to go with a 5speed. Either the Mazda M5OD or ZF5.
Old Oct 24, 2023 | 07:24 PM
yardbird's Avatar
yardbird
My '87 has 3.08 with 30" tires (30x9.50x15), and can run 75 without too much of a strain on the rpms. 70 mph is still under 3000, around 2700 I think. I have a NP- 435, 4 speed direct transmission.
Old Oct 24, 2023 | 09:09 PM
Hit Man X's Avatar
Hit Man X
My vote for an AOD also. Easy to acquire and freshen up.
Cbibb
15
Nov 13, 2021 01:14 PM
devall97obs7.3
16
Oct 15, 2014 09:41 PM
ech0sh4y
May 30, 2007 12:30 AM
