Stupid Darn Headers
Old Nov 21, 2003 | 05:26 PM
stratton's Avatar
stratton
Stupid Darn Headers
so i got these cheap flowtechs from autozone because i'm a tightwad and they don't work. drivers side went on in 30 minutes, have been working on passenger side for 3 days.
never seen anything like it. the tubes go both sides of the engine mount (2 in front 2 behind ) is this normal ?? also had to bend in about 4 places to get the engine bolted back down then 2 tubes pulled out of the collector. drove it to the muffler shop where they laughed at me and said there was no way this was the right header whats goin on ?? anyone else have these problems ??
headers mis-boxed ??
also can i install my oil pump driveshaft from the top - distributor side
thanks
Old Nov 21, 2003 | 05:41 PM
Ratsmoker's Avatar
Ratsmoker
You got the wrong flowtech bud. Mine went right in without moving the engine. No slipjoints on mine either.
Old Nov 21, 2003 | 05:59 PM
Andysutt's Avatar
Andysutt
Get dynomax's from Jegs...
I got mine and they slip right in like Ratsmoker said
I got ps and power brakes and had no problem
Old Nov 21, 2003 | 08:22 PM
tojoski's Avatar
tojoski
i got those from autozone as well for my 66 and the only thing i had to do was ding one tube in slightly for the starter stud
i did however have the passenger side inner and outer fender off at the same time, and i remember thinking that i was screwed when i came time to take them off
Old Nov 21, 2003 | 10:32 PM
Freightrain's Avatar
Freightrain
Yup, my Dynomax's went on pretty easily also.
As for oil pump drive. NO.
You might be able to "drop" it thru, but the chance you will actually make it into the pump is SLIM to NONE. Plus, if you ever want to pull dist, it will come up with it and drop into pan and you will be in deep do-do.
Sorry, you need to drop pan and install it correctly.
Larry
Old Nov 21, 2003 | 10:34 PM
gtex's Avatar
gtex
Dynomax plus Bendix PS gear....not compatible. Personal experience.
Old Nov 21, 2003 | 10:39 PM
Andysutt's Avatar
Andysutt
I have no bendix PS gear
Old Nov 22, 2003 | 01:46 AM
pat67shorty's Avatar
pat67shorty
Uaually the 4wd headers split around the motor mount. A miss boxed header perhaps?
