Carroll Shelby block
Old Nov 21, 2003 | 04:32 PM
xericx's Avatar
xericx
I was wonder, could I use 390 crank and rods with 427 pistons in one fo Carroll Shelby 427 alum. blocks?
Old Nov 21, 2003 | 05:00 PM
Ford_a_holic's Avatar
Ford_a_holic
Where did you get a Carroll Shelby 427 alum. block?
Old Nov 21, 2003 | 05:05 PM
fordman428's Avatar
fordman428
thats what i was wondering, an alum. block thtas lots of $$$$$$
Old Nov 21, 2003 | 05:54 PM
xericx's Avatar
xericx
Well I havent bought onbe yet, but am really thinking a bout, I mean its only lik 5 grand
Old Nov 21, 2003 | 05:58 PM
fordman428's Avatar
fordman428
what do you plan on putting it in.
Old Nov 21, 2003 | 06:25 PM
xericx's Avatar
xericx
72 ford p/u
Old Nov 21, 2003 | 06:40 PM
Scouder's Avatar
Scouder
Yes. It makes it a 427 with a cast crank. Keep it under 6500 rpm and it'll work fine. Blocks are $5500 after you add the required head studs.
-Scouder
Old Nov 21, 2003 | 06:52 PM
xericx's Avatar
xericx
Thanks Scouder, what do you guys think, leave the block shiny alum or paint it to be a sleeper?
Old Nov 21, 2003 | 09:13 PM
JonnyB69's Avatar
JonnyB69
I say paint it. I love a good sleeper truck when some guy in a Honda pulls up next to ya and revvs their engine.
Old Nov 22, 2003 | 02:22 PM
Scouder's Avatar
Scouder
No paint for this boy. I'm leaving mine aluminum top to bottom. They can't see it from the lane next to you, and after you smoke the first guy the secret is out anyway. Might as well show what you got.
-Scouder
Old Nov 22, 2003 | 07:46 PM
Ratsmoker's Avatar
Ratsmoker
I wish I could afford an aluminum block. I wouldn't paint it if I could. I might polish it but no paint. I wouldn't use a 390 crank if I had one. What is $700 more for a 4.25 SCAT crank and another $800 for some custom forged rods and $500 for some pistons. Carrol shelby made that block and wanted to run 1500HP through it via forced induction to break his 0 - 100 - 0 record. It is not just for weight reduction. It is much stronger than the original 427.
Old Nov 22, 2003 | 09:26 PM
xericx's Avatar
xericx
I was just think 390 crank and rod cause I have some lying around. How about this combo http://www.flatlanderracing.com/stroker427485.html.
Can some one desktop dyno this for me with bout 9.5 comp, 750 carb, ebrock performer rpm, ebrock 76cc heads and this cam
Hydraulic
108 center
INTAKE TIMING DURATION: 270 deg.
OPEN: 27 BEFORE TDC
CLOSE: 63 AFTER BDC
CAM LIFT: .310"
VALVE LIFT: .542"
EXHAUST TIMING DURATION: 270 deg.
OPEN: 63 BEFORE BDC
CLOSE: 27 AFTER TDC
CAM LIFT: .310"
VALVE LIFT: .542"
Old Nov 22, 2003 | 09:54 PM
Ratsmoker's Avatar
Ratsmoker
I need the .050 duration as well.
Old Nov 23, 2003 | 08:13 AM
Ford_a_holic
$5500 for a bare block?!
Old Nov 23, 2003 | 10:27 AM
Scouder's Avatar
Scouder
New to 427's? Unused original Ford iron 427 side oilers blocks commonly go over $5000.00 on ebay.
The Shelby block is aluminum with replaceable dry sleeves, bores out to 4.44", has reinforced valley area, double cross bolted mains, supports strokes up to 4.5" and will handle 1500 plus HP. It is also quite comparable with other aluminum blocks of comparable features price wise.
$$$ are the reason that 427s are so rare, and are spoken of in hushed tones and awe!
-Scouder
