2021-2023 Ford F-150 LED Upgrade Bulb Size Guide
Seeking the ultimate recipe for upgrading your Ford F-150 to LED? This all-inclusive guide has everything you need for an illuminating success story. The crucial step is identifying your F-150's OEM halogen bulb sizes, as the correct LED matches are the key to a smooth and hassle-free installation. Our meticulously compiled bulb size chart covers most halogen lights spanning from 2021 to 2023 for the Ford F-150. With the precise LED bulb sizes that align perfectly with your existing halogens, you have the perfect formula to give your truck a stunning LED makeover. Follow our tried-and-tested techniques to cook up an LED upgrade that will take your F-150's lighting capabilities from ordinary to extraordinary.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H10/9145
Cargo Light: T15/921/912
3rd Brake Light: T15/921/912
Front Side Marker Light: T10/168/2825
License Plate Light: T10/168/2825
Back Up Light: WT21W
Front Turn Signal Light: 4257
You can try Lasfit LED bulbs on your Ford F-150. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LAplus H11
We would like to recommend Lasfit LAplus series H11 LED bulbs for your Low Beam Light. LAplus H11 LED bulbs are much brighter than halogen, 30W, 3000LM per bulb, 6000K bright white. New cooling system with a unique ball-bearing fan for heat dissipation makes the bulbs more lifespan. The 360 Degrees Adjustable Socket allows adjusting the beam pattern.
High Beam: LAplus 9005
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on F-150. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Fog Light: LAplus H10
LAplus H10 LED bulbs are much brighter than halogen, at 30W, 3000LM per bulb, with 6000K bright white light. Built with a smaller/shorter size than common market LEDs without an external driver, they plug directly into the factory housing. A new cooling system with a unique ball-bearing fan provides heat dissipation for longer lifespan. You won't be disappointed with LAplus H10!
Front Turn Signal Light: T-4257A(Amber)
1600LM/bulb, 24W/bulb. CANBUS system can prevent hyper flash and error warning. No need to add extra resistors or parts anymore. They are designed to directly plug and play. Upgrade function for switchback coming with the brighter mode for turn signal light and the normal mode for DRL/driving indicator. An excellent Intelligent Temperature Control system will protect bulbs against excessive current and overheating and ensure a longer lifespan.
Back Up Light: T-WT21W(White)
1600LM per bulb, 6000K pure clean white light output, designed to replace factory reverse/backup lights! 100% plug-and-play installation can be completed in about 5 minutes on most vehicles, with nothing more than basic tools. Direct fit with zero modification to your factory setup. Built-in mini fuses protect the bulbs and your from instantaneous high current, allowing safer installation and use.
Cargo Light & 3rd Brake Light: L-T15(White)/L-T15R(Red)
1400LM/set, 6000K bright white. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design. Depending on the position and function, you should choose white for cargo lights and red for 3rd brake lights.
Front Side Marker Light & License Plate Light: L-T10A(Amber)/L-T10(White)
800LM/set, much brighter than OEM halogen bulbs. It's necessary and easy to achieve to add a modern appearance to your truck by replacing stock halogen bulbs with this LED bulbs. No need any modification, just for plug-and-play installation.
Real Review from Lasfit customers
Huge thanks to them for sharing their experience with great pictures!
Case1:
2023 F150 - STX
Bought the total LED package now just waiting for R&D to come up with the ones left. As soon as they do, this guy is buying them. Totally happy with the product, the delivery and the customer support. Definitely can’t go wrong with Lasfit! Oh and while I was grabbing the LED’s I picked up the floor mats as well. 5 star on those as also. Great fit and well made!——S.H.
Case2:
2022 F150 STX 4X4 with BLISS
Great Kit, Very Bright and well made lighting. Would deffinantly buy again. Back Up light bulbs did not work in kit due to the OEM light having a built in LED Module. LASFIT customer service was excellent and took care of the issue.They have been a great company to deal with.Pictured below you can tell the difference.——J.K.
Case3:
21 f150 sxt
Purchased the whole package and wow! What a difference!! Some things to note:The side marker lights need some persuasion to get in due to the thickness of the base. They will 100% fit but you gotta press pretty hard.
If you don’t have BLISS, you can 100% get bulbs that fit the unlisted positions. Pull your current bulbs and match them to what Lasfit has available WOTH RESISTORS!!
I also upgraded the low beams and high beams to the LS series bulbs. Whoa! They say they don’t fit, but they do IF you modify the dust cap to fit the wires and ensure adequate ventilation for the fans to disperse heat.They are BRIGHT!!
100% beyond satisfied with these bulbs.——M.C.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H10/9145
Case1:
2023 F150 - STX
Case2:
Case3:
21 f150 sxt
LASFIT
2009 - 2014 F150
10-13-2023 06:43 PM
LASFIT
2015 - 2020 F150
10-12-2023 08:37 PM
Valli AUXITO
1999 to 2016 Super Duty
05-23-2022 09:45 AM
HorsePower Junkie
08-04-2021 08:31 PM
HorsePower Junkie
2009 - 2014 F150
08-04-2021 09:23 AM
