Tuners
Old Oct 18, 2023 | 12:23 PM
jcwf450's Avatar
jcwf450
3rd Gear
Tuners
Has anyone heard of or tried to use chipyourcar.com on their diesel truck?
I am looking into buying this chip for my F450.
Old Oct 19, 2023 | 07:02 AM
IADiver's Avatar
IADiver
Is that kinda like Pimp You Ride?
Old Oct 19, 2023 | 10:31 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
I call snake oil on that. The only way to properly tune your F450 is with a flash programmer that programs your ECU and TCU.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 19, 2023 | 12:50 PM
doczenith1's Avatar
doczenith1
Run Forest, run!
Old Oct 20, 2023 | 08:41 AM
speakerfritz's Avatar
speakerfritz
it depends what the goal is
a lot of folks need a “tune” so they can disable certain things that epa doesn’t want us to talk about.
the tune for more power, or other performance goals doesn’t necessarily require a reflash type of activity and you head into murky waters with alligators lurking if you go that route for the simple reason of service departments reflating back to stock for various reasons. There are a lot of folks that come on this forum with trucks that had a flash type tune which the service department relished for what ever reasons and now they have a brick which difficult solution options.
these chip in a box performance devices are just passive interference devices that trick your map, temp, and fuel pressure sensor to believe there are different conditions than actual and end result more fuel so that the sensor readings rest where desired…and there is a rich fuel mix resulting in more power…and more soot in most cases.
there are other interference type of devices that have some intelligence at work that the operator can multiple pick from and provide data such as the banks deringer
then, of course, you can also get more power, cleaner burn, cooler exhuast with no flash or interference type of devices by just adding an AEM methonal /water infection system (about 500 bucks).
JTQ0919
Connecticut Chapter
Jan 9, 2013 07:22 PM
f-250diesel
Jan 20, 2010 12:59 PM
JDWIS
Oct 26, 2004 01:08 PM
4WheelE350
Computer Chips & Tuners
Jul 28, 2001 11:23 PM
