2018-2020 Ford F-150 LED Upgrade Bulb Size Guide
Frustrated with the complexities of upgrading your Ford F-150 to LED? Look no further! This comprehensive guide is here to make your life easier. We'll help you navigate through the process of identifying the OEM halogen bulb sizes and finding the right LED replacements. With our detailed bulb size chart, you can rest assured that you'll have the correct LED bulb sizes for a seamless installation. Say goodbye to the headaches and confusion, and say hello to a sleek and modern LED upgrade for your Ford F-150.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H10/9145
Cargo Light: T15/921/912
Center High Mount Stop Brake Light: T15/921/912
Front Side Marker Light: T10/168/2825
License Plate Light: T10/168/2825
Reverse Light: 7443/7444
Front Turn Signal Light: 7443 for 2018/4257 for 2019-2020
You can try Lasfit LED bulbs on your Ford F-150. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LAplus H11
We would like to recommend Lasfit LAplus series H11 LED bulbs for your Low Beam Light. LAplus H11 LED bulbs are much brighter than halogen, 30W, 3000LM per bulb, 6000K bright white. New cooling system with a unique ball-bearing fan for heat dissipation makes the bulbs more lifespan. The 360 Degrees Adjustable Socket allows adjusting the beam pattern.
High Beam: LAplus 9005
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on F-150. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Fog Light: LAplus H10
LAplus H10 LED bulbs are much brighter than halogen, at 30W, 3000LM per bulb, with 6000K bright white light. Built with a smaller/shorter size than common market LEDs without an external driver, they plug directly into the factory housing. A new cooling system with a unique ball-bearing fan provides heat dissipation for longer lifespan. You won't be disappointed with LAplus H10!
Front Turn Signal Light: T-7443D(Switchback) for 2018
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Built-in anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Front Turn Signal Light: T-4257A(Amber) for 2019-2020
1600LM/bulb, 24W/bulb. CANBUS system can prevent hyper flash and error warning. No need to add extra resistors or parts anymore. They are designed to directly plug and play. Upgrade function for switchback coming with the brighter mode for turn signal light and the normal mode for DRL/driving indicator. An excellent Intelligent Temperature Control system will protect bulbs against excessive current and overheating and ensure a longer lifespan.
Back Up Light: L-7443(White)
1200lm/set, xenon white. L Series bulbs have an impressively bright, pure white, sharp light output with a unique metal style. Built-in Constant Current IC Driver ensures a bright, efficient and long-lasting illumination.Non-Polarity Design. You needn't worry whether you have a CK or Non-CK socket, these bulbs are universally compatible.
Front Side Marker light & License Plate Lights: L-T10(Amber)/L-T10(White)
800LM/set. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Cargo Lights & Center High Mount Stop Lights: L-T15(White)/L-T15R(Red)
1400LM/set, 6000K bright white. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design. Depending on the position and function, you should choose white for cargo lights and red for Center High Mount Stop lights.
Real Review from Lasfit customers
Huge thanks to them for sharing their experience with great pictures!
Case1:
Love Em
When I first installed the lights, there was a night and day difference between them. I can honestly say that I love 'em. Only regret is that I wish I had done this a long time ago. Only knock that I have is that the side marker lights are no different than the halogen bulbs. Practically the same. Those are the only ones that I would have left alone. Other than that, I love these lights. So far no one has flashed their headlights at me saying mine were too bright or in their eyes, if that makes any difference.——A.P.
Case2:
2020 Ford F-150
I got the Led package for my dim lit 2020 F150 FX4. The improvements are remarkable. Couldn’t be happier with the product. My only advice, get some larger grommets for the back of the headlights. The factory ones do not seal since the new bulbs have fans. But a great product. Will definitely do business again.——T.C.
Low Beam: H11
High Beam: 9005/HB3
Fog Light: H10/9145
Case1:
Love Em
Case2:
2020 Ford F-150
LASFIT
2009 - 2014 F150
10-13-2023 06:43 PM
LASFIT
2015 - 2020 F150
10-12-2023 08:37 PM
chadstickpoindexter
2017+ Super Duty
17
11-01-2022 08:26 PM
