Transflow 58 Won’t Fill
Old Oct 14, 2023 | 06:28 PM
dugals's Avatar
dugals
My 58 gallon Transflow which has been fine until today when I went to fill it. I could only pump less than a gallon when the pump shut off and gas backed-up from the filler tube. My guess is a venting problem. Has anyone had this problem and how did they solve it? I guess I’ll have to call Transflow on Monday. Thanks
Old Oct 14, 2023 | 07:56 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, I'd check the vent, maybe snake it out to make sure it's not blocked.
Old Oct 14, 2023 | 08:54 PM
dugals's Avatar
dugals
Good answer but how do I check the vent?
Old Oct 14, 2023 | 09:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That's why I said snake it out, run a stiff wire through it to see if anything is blocking it.
Just my suggestion, but I don't know exactly how the transfer flow tank vent is setup.
Old Oct 15, 2023 | 09:57 AM
swej2006's Avatar
swej2006
Hiya have to been able to fine a fix?
Old Oct 15, 2023 | 10:01 AM
dugals's Avatar
dugals
Not yet. Someone from the Tremor forum said it happened to him and he said he filled it slowly. I haven't been back to gas station to try it yet. Any ideas?
Old Oct 15, 2023 | 10:34 AM
Mike Bartlett's Avatar
Mike Bartlett
I would confirm it’s your tank that is at fault. There is a good chance that particular pump nozzle was the problem. I have a sports car that doesn’t like certain pumps and constantly clicks off other stations it will work fine. Not sure what state you are in but here in CA we have the anti-backsplash/vapor pumps which make it tough at times. Bottom line double check your problem it may not be your tank.
Mike
Old Oct 15, 2023 | 11:14 AM
dugals's Avatar
dugals
Yes - my jeep does the same thing at certain pumps, but what concerns is that there is splash back and overflow out of the filler pipe even after the pump clicks off.
Old Oct 16, 2023 | 07:12 PM
dugals's Avatar
dugals
Well, I went to fill up, really feathered the pump and got it filled up. Took me about 20 minutes standing there. Don't know why the change - I've filled it about 10 times and never had this issue. Cheers
Old Oct 16, 2023 | 07:47 PM
Mike Bartlett
I assume this was a different fuel station from the last time when you had the problem? If so my guess would be the vent side as others have mentioned. Maybe reach out to the manufacturer as well?
Regards,
Mike
Old Oct 16, 2023 | 08:19 PM
dugals's Avatar
dugals
It was the same station but a different pump. I carefully watched the 2 vent holes to make sure the weren't blocked and air was being exhausted. I probably should reach out to transferflow. Cheers
Wolff5599
2009 - 2014 F150
Oct 13, 2017 12:28 PM
BenFranklin
6.2L V8
13
Apr 24, 2017 12:43 PM
Re-Possessed
25
Mar 12, 2006 01:15 AM
vesuvius5402
Jun 8, 2005 03:48 AM
horns1969
Sep 29, 2004 01:43 PM
