Sponsored by: Real Truck
Esof Plug
Old Oct 10, 2023 | 08:01 PM
Hopper123's Avatar
Hopper123
Esof Plug
The plug that plugs into the transfer case has a broken clip. It slips off now and again. Is it possible to replace just that part of the harness or is their another way to get it to stay on?
Old Oct 10, 2023 | 08:24 PM
00t444e's Avatar
00t444e
If it was me I would swap to a manual shift transfer case.
Old Oct 10, 2023 | 08:27 PM
bajaphile's Avatar
bajaphile
Is there a writeup on this? I'd like to do it but want to get all the parts together first before going for it.
Old Oct 10, 2023 | 08:36 PM
Hopper123's Avatar
Hopper123
Maybe this will help you. Plan on doing it one day
https://www.ford-trucks.com/forums/1...4-shifter.html
Old Oct 10, 2023 | 08:37 PM
00t444e's Avatar
00t444e
Yes there is several if you do a search. It is a pretty straightforward swap. You need a manual shift NV271 transfer case with the correct input shaft, the shifter linkage, shift handle and shift boot. There is already a plate under the carpet that you can take off to run the shift handle through and the holes to screw the boot trim piece are already there also.
jimbbski
2009 - 2014 F150
Apr 2, 2017 11:50 AM
suthrnslew
22
Jun 4, 2009 05:10 PM
DR JOE
Dec 9, 2008 08:41 PM
